Author Topic: manual trans neutral switch  (Read 6207 times)
lynnbilodeau
« on: May 15, 2013, 04:48:24 AM »
Did the late 69 manual trans cars use the white plastic switch used on the 70 models?
I know the early cars had the round metal switch.
rszmjt
Re: manual trans neutral switch
« Reply #1 on: May 15, 2013, 03:36:40 PM »
I have never seen the white 70 switch on 69, A friend has a 11B/69 and it has the metal switch like below.
http://www.heartbeatcitycamaro.com/store/product/12742/Camaro-Neutral-safety-switch-4speed-1969/
« Reply #2 on: May 15, 2013, 03:58:22 PM »
Lynn,
assuming that the 'neutral safety' switch is the same as what I've called the 'Rev LO switch' ??  (see photo)
... then Yes, my late 09C Z28 has the white plastic switch.   THis is my original column and switch; never been exchanged or removed until I took the column out for cleaning a couple of months ago.  My car was built approx  17 Sept 1969.
lynnbilodeau
« Reply #3 on: May 15, 2013, 04:47:16 PM »
Meant the switch on the clutch pedal, not the reverse light switch.
I believe the automatic cars have the neutral switch integrated with the reverse light switch.
Was pretty sure it took the round metal switch on the clutch pedal, but I have one of the plastic 1970 switches, and have no idea where it came from.
Thanks.
« Reply #4 on: May 15, 2013, 05:50:34 PM »
Lynn,
it's located on the clutch pedal lever?    I've never looked at mine..    but I'll peek under there and see..  :)
so basically it's the switch that ensures you have the clutch pushed in to start the car.. (a 'clutch-engaged' switch).  :)
I haven't driven that car since 1980... my memory is going. :)
69Z28
  • 69 X33D80 Z28
« Reply #5 on: May 15, 2013, 06:28:33 PM »
Gary.
You gotta really look up in there to see it.
GaryC
« Reply #6 on: May 15, 2013, 06:49:12 PM »
I happen to have most of my instruments out of the way right now, so it's not difficult to see..
Mine is a metal cyclindrical can wtih black plastic cap (terminal end?)...  I could probably get numbers off it if you wanted ..
Gary
Hans L
« Reply #7 on: May 15, 2013, 09:18:44 PM »
Not sure about late model - here's mine, refreshed and cleaned but original.  04B VN Z..
'69 Chevelle SS 396 4 Speed
« Reply #8 on: May 15, 2013, 09:30:31 PM »
The one from my late September (09C) Z28 is the same as the one Hans pictures...
lynnbilodeau
« Reply #9 on: May 18, 2013, 02:33:28 PM »
That's the one.
ZLP955
« Reply #10 on: May 19, 2013, 02:53:24 AM »
My original switch has black plastic just like the one Hans posted too, although it's not a late '69 car....
Tim in Australia.
