Author Topic: Vacuum headlight doors not working  (Read 4784 times)
Red_Witch
« on: August 16, 2006, 03:41:10 PM »
We have a 68 rs/ss and the vacuum headlight doors will not close. :-\ Anyone have any ideas or solutions? Any help appreciated.\
rich69rs
  • LF7/M35/Z22/Z87
Re: Vacuum headlight doors not working
« Reply #1 on: August 16, 2006, 06:02:14 PM »
Following related specifically to '69, but hopefully can get you going in the right direction.  As a start, is the manual slide switch on top of the relay valve in the "normal" position.  If it has been moved from the nomal position, the doors will stay open.
See following links as well as the attached Word document.  I found it on the Internet, and I don't have the source documented, so I can't give proper credit to the originator - but it is a pretty good descriptive document:
http://www.camaros.org/forum/index.php?topic=542.0
http://www.camaros.org/forum/index.php?topic=626.0
« Last Edit: August 16, 2006, 06:19:35 PM by rich69rs »
Richard Thomas
1969 RS
