Author Topic: Correct posi tag for rear on '69  (Read 10281 times)
nuch_ss396
« on: August 12, 2006, 03:28:17 AM »
Hi everyone,
I'm trying to find an original posi tag & plug for my 12-bolt rear.  Can anyone post an image of the correct
( original ) posi tag & plug combination for the 69 12-bolt rear?  I believe the originals had incused lettering
that was back filled ( with white ), while the newer ones seem to indicate a silk screened process being used.
I have also seen different fill plug styles as well.  Possibly with different size heads.  What is correct for my
Camaro?  If it matters, it is an early build ( 10-D-68 ).
These items show up on eBay from time to time, but I am hesitant to buy as I know only one is probably correct.
69 SS 396, Hugger Orange, D/80, D/90
Chambered Exhaust, N/66, THM400, 3:73 posi
Steve A.
mr396
    • 1968 camaro SS 396 RS convertible
Re: Correct posi tag for rear on '69
« Reply #1 on: August 12, 2006, 03:46:44 AM »
My 68 looks like this.I think 69 is the same.
1968 camaro RS/SS L34 396 air convertible
nuch_ss396
« Reply #2 on: August 12, 2006, 05:48:13 AM »
mr396,
Is your tag original, service replacement, or reproduction?  Are the letters incused ( cut in ) or silk screened?
Steve A.
copo
« Reply #3 on: August 12, 2006, 06:58:38 PM »
That tag is incorrect for a 68-69, the correct tag should say (USE POSITRACTION DIFF LUBRICATION ONLY)  The white letters are silk screened on and not cut in to the plastic tag. The hole size is 3/4 inch. Ricks Camaro sells a repo of this tag but the letter fonts are not same as compared to a original tag.
mr396
« Reply #4 on: August 12, 2006, 07:51:21 PM »
I am sure mine said Limited slip on my 68 tag.That picture is from ricks catalog. I took my tag off and put it away,  and as soon as I remember where I put it, I take a picture and post it. My camaro only had 50,000 miles on it when I got it and thought the posi tag to be original.
copo
« Reply #5 on: August 12, 2006, 08:15:43 PM »
There is a original 69 posi tag on Ebay right now, item # 160016105260, this is the same tag I have.
nuch_ss396
« Reply #6 on: August 13, 2006, 02:56:09 AM »
Thanks COPO!
As Maxwell Smart said so well, "Missed it by that much !"
Steve A.
