Author Topic: Please Verify  (Read 2612 times)
69houdini
  • 69 SS X55 Butternut Vert / 68 Z28 Rally Green
Please Verify
« on: March 13, 2013, 05:01:16 PM »
Hey Guys I just need a verification to be sure I did my homework correctly, could you please help.
I am restoring my 68 Z28 which is going in for paint and want it to be correct in color. The car is a J2 paint code, Ralley Green w/ black Vinyl top. PPG paint Code 43898
The white stripes are Ermine White PPG paint Code 8259 and the interior Dash panel is Black PPG paint Code 9266
I know this has been asked before but are the Rocker panels blacked out and if so what PPG paint code # is it.
This is a great site and appreciate all the discussions and help everybody contributes.
I'm hoping to get this car on the road by June 2013, Thanks for your help. John
Re: Please Verify
« Reply #1 on: March 13, 2013, 05:11:51 PM »
John,
In '68, the body sill black-out paint was applied to a Rallye Green car only if it had the Rally Sport (Z22) appearance package.
69houdini
Re: Please Verify
« Reply #2 on: March 13, 2013, 06:17:14 PM »
Thanks, not an RS
Re: Please Verify
« Reply #3 on: March 17, 2013, 01:56:59 AM »
I believe the stripes should be black.
Re: Please Verify
« Reply #4 on: March 17, 2013, 04:13:56 AM »
The table says they should be white, for 68. http://www.camaros.org/numbers.shtml#ExteriorColors
Bill, for 69 you are right, they would be black with the black top.
69houdini
Re: Please Verify
« Reply #5 on: March 17, 2013, 03:51:52 PM »
I do like the Black Stripe w/ Black Vinyl Stripe and Black Interior combo but I want to be as correct as possible and will go with the White Stripes, I want to be sure my PPG codes are correct for 1968 Camaro Z28, Thanks
Re: Please Verify
« Reply #6 on: March 18, 2013, 01:15:37 AM »
I'm no paint expert but from the little I think I know having the current PPG paint code does not necessarily mean the color will be a correct match. I've seen differences between the results of Dupont and PPG paint codes for what was supposed to be the same color/same year. Hopefully a paint expert will chime in.
Re: Please Verify
« Reply #7 on: March 18, 2013, 10:12:50 AM »
AND not all colors can be duplicated in base/clear, if that is what you are useing.
