Author Topic: Sunoco 260  (Read 14953 times)
GI JOE
Sunoco 260
« on: February 24, 2013, 12:22:52 AM »
 ;D ;D ;D
Does anyone remember
Sunoco 260 ?
Was it 102, 104, 110 or 120 octane?
Please don't look it up .. just put down what you remember...  BTW I believe that Sunoco did change the octane several times...
SFC GI JOE - Airborne Paratrooper
68- L-78, M22, BV
69- L-78, M22, BV, Conv
Re: Sunoco 260
« Reply #1 on: February 24, 2013, 12:37:06 AM »
 I used that in my 69 Grand Prix Model J back in '73. I *think* it was somewhere around 102 or 104, if that high.
Back in the days when you could get real leaded gas.
Re: Sunoco 260
« Reply #2 on: February 24, 2013, 01:00:24 AM »
I'm thinking around 102. Hess was higher at around 104.
GI JOE
Re: Sunoco 260
« Reply #3 on: February 24, 2013, 03:46:44 AM »
Wow i did not know about Hess... or I have forgotten after all these years...   :-\
68- L-78, M22, BV
Re: Sunoco 260
« Reply #4 on: February 24, 2013, 03:55:23 AM »
I worked at a Sunoco station when I was 18 (1979). I tried to get jobs as a teen where I could learn how to work on cars. The owner let me use the lift at night. The pump had a lever on the side that let you dial the octane requested. Many hot running cars came in to get gas. I saved the round blue medallion off the pump when Sunoco did away with that blend. I think it was 102 octane,also,but hey, at my age,I can't even remember what I had for dinner.LOL
MyRed67
  • SZZLN 67
Re: Sunoco 260
« Reply #5 on: February 24, 2013, 06:24:20 AM »
Through our High School years my brothers and I work at our Grandfathers DX Station which changed to Sunoco I believe around 1970.  I remember my younger brother burnt the valves in a '68 Chevelle SS396  325 hp. running 260 all the time.  I think 102 octane is about right IF memory serves me right.  But at my age my memory kind of plays tricks sometimes.
1967 Camaro  LOS  11A
Original Engine   Z - Tribute
Mike C.    NW - Illinois
Re: Sunoco 260
« Reply #6 on: February 24, 2013, 05:44:14 PM »
I thought it was 110 but prob 104.
Re: Sunoco 260
« Reply #7 on: February 24, 2013, 06:02:05 PM »
Note that the octane rating systems have changed since the days of the 260 pumps in the 60's-70's; in those days, only the "Research Octane" (RON) number was used, not the lower "Motor Octane" (MON)number. 260 was rated at 102-103 octane by the "Research" method, and 95 octane by the (seldom-used) "Motor" method.
L-88 Corvettes had 12.5:1 compression, and had a sticker on the shift console that said that fuel used must be a minimum of 103 Research Octane or 95 Motor Octane or engine damage could result (from detonation).
In today's world, fuels are identified on the pump by the new "Pump Octane" (PON) number, which adds the RON octane number and the MON octane number together and divides by two (RON + MON/2). If you could buy 260 today, the pump would show 99 octane (103 + 95/2).
Good premium fuel back in the day was rated at 97-98 octane by the "Research" method, and at 88 octane by the "Motor" method; with today's mandated PON pump-octane formula, that converts to a 93 octane PON number that would be on the pump today. Today's 93 octane fuel is the same as yesterday's 97-98 octane fuel; you'll find 98 octane on the premium pump in Europe today, as they only use the "Research" octane number on the pump.
When we built our retirement home/garage in 2000, my wife bought me a restored Sunoco 260 dial-your-octane pump as a housewarming gift for the garage, but she forgot the 8,000-gallon underground tank full of 260 to go with it.  ;D
lakeholme
  • 68-12D L30/M35
Re: Sunoco 260
« Reply #8 on: February 24, 2013, 06:19:17 PM »
...Just like John said.  ;D
All the confusion comes from the "custom blending" capabilities of the Sunoco "Dial A Grade" pumps that offered "octane grades" from 190 to 260 --subregular to super-premium, whose numbers didn't actually reflect the MON octane ratings.  It always struck me as more about marketing than performance.  I do remember, however, that they sold good gas.
BTW, as a teenager, I always wanted to look inside those Dial A Grade pumps to see how they blended all those grades...
Re: Sunoco 260
« Reply #9 on: February 24, 2013, 06:41:43 PM »
Great Info JohnZ..  :)   and SUPER photos...   I always love seeing pix of your auto den..   uh...  I mean..  garage.. :)
Re: Sunoco 260
« Reply #10 on: February 24, 2013, 07:26:14 PM »
John, awesome photos.
Garage?  That looks better than a museum, and cleaner too!!!
Re: Sunoco 260
« Reply #11 on: February 24, 2013, 07:55:15 PM »
Just filled my motorcycle up with some 100 octane.
GI JOE
Re: Sunoco 260
« Reply #12 on: February 24, 2013, 08:27:12 PM »
but she forgot the 8,000-gallon underground tank full of 260 to go with it.  Grin
John, I really got a chuckle out this...   ;D  thank you.
and BTW... that is a sweet garage... ;D
68- L-78, M22, BV
GI JOE
Re: Sunoco 260
« Reply #13 on: February 24, 2013, 08:31:02 PM »
FYI  - Here is some more info on the gasoline octane; IMHO  ;)
Octane is an 8-hydrocarbon chain and is more compressible without spontaneous detonation.  Heptane is a 7-hydrocarbon chain. It is very volatile and it ignites spontaneously under very little compression.  So 87 grade gasoline is 87% octane & 13% heptane which ignites at a given compression level.  87 grade is known as Regular gasoline.
Basically what you need to know is that you will get the maximum power from running the lowest octane without detonation... so if you can run 87 octane run that.  The higher grade octanes are only to prevent spontaneous detonation (aka engine knock - very bad).
As you probably know most Chevy Camaro's had average to high compression ratios (i.e. about 9:1 I think for the 327, the L78 11:1, the L72 12:1, L88 & ZL1 12.5:1). The 10:1 and higher ratios would not run without detonation under 93 octane gasoline and that might have been pushing it for the 427's.
The higher the compression ratio the more power the engine made. (the 11:1 and higher stuff was really Hi-Perf race-car levels.) If I remember right, GM required these engines to run on a minimum of 98 octane gasoline; aka Super gasoline, Premium gasoline, etc...
68- L-78, M22, BV
GI JOE
Re: Sunoco 260
« Reply #14 on: February 24, 2013, 09:25:24 PM »
" BTW, as a teenager, I always wanted to look inside those Dial A Grade pumps to see how they blended all those grades... "
Hi Phill,
I believe it was done the same as today, basically with a blending type valve. Turning the dial selected the preset blend ratio.  So a selected grade would be made up of so much high test (Super gas) and so much of the regular gasoline...  just roughly figuring I think it goes like this;  to get 89 octane the blender takes a preset ratio at about 40% 93 octane and then take about 60% regular 87 octane blending them together for the 89 octane.  (It might be more complicated than that but I think that is the approach.)  Joe   :-\
PS  - in the photo just above the center filter I think is the metering blend valve... the blue thing to the left is a Wayne vacuum motor used for collecting the gasoline vapors from your cars tank as you pumped gas...
68- L-78, M22, BV
