Author Topic: 69 smallblock (302) Oil dip sticks  (Read 30068 times)
« on: January 31, 2013, 02:20:55 PM »
I removed and disassembled my original 302 engine in my Z28 many years ago, stored the parts away (using the 'store' term loosely), and installed a 350 LT-1 engine for awhile.   The car has sat undriven in my garage since 1980, but the last 3-4 yrs, reading this forum has gotten my juices flowing about cleaning up the car, reinstalling all the original parts, etc.  I spent probably a year searching thru my 'garage 'storage' looking for the parts I removed and *stored*... :). but hadn't been able to find a 'green tipped' oil dipstick, which most of the stuff I'd read said my Z28 should have come with.   a week or so ago, I saw a dipstick/tube laying with a pile of 'crap' (in storage in my garage), but noticed it didn't have the green tip, but it triggered my old memory a bit.   This one had a flattened tip on the handle and no green tip, see photos,  so I've been searching for information on original '69 Z28 dipsticks.
I came across a great thread and post on Yenko.net regarding '69 Z28 dip sticks..  link below for anyone wanting some great data!!
http://www.yenko.net/ubbthreads/ubbthreads.php?ubb=showflat&Number=416817#Post416817
This thread and post with labeled photos, seems to totally address the question of '69 Z28 dip sticks.. :)
AND.. I find that I do have my original dip stick..  which makes it even more great!
Stingr69
Re: 69 smallblock (302) Oil dip sticks
« Reply #1 on: January 31, 2013, 03:48:00 PM »
They were not originally "green tipped" but some dip sticks sold as service replacements are. The picture you posted with the flatened handle end looks more like what I would expect to see as production line pieces.
-Mark.
« Reply #2 on: January 31, 2013, 04:06:40 PM »
There were several older threads on this subject, but the pictures have disappeared.
Here are a couple of photos of an original '69 302 dipstick. From the bottom of the metal seal cup, it's 18-7/8" to the tip, 17-5/8" to the "add" mark, and 16-3/4" to the "full" mark.
« Reply #3 on: January 31, 2013, 04:22:07 PM »
JohnZ,
Your dipstick matches mine.. :)..  and match the photos supplied in the Yenko.net link I referenced earlier.
Note:  I also did fine an older post from you that also supported that, but there is an abundance of faulty information on the Camaro boards about 'correct green tipped' dip sticks.. and that threw me off in finding mine in my junked up garage for a LONG time.. :)
68Zproject
« Reply #4 on: January 31, 2013, 10:24:18 PM »
Maybe there were some "dipsticks" posting bad info?
68Z28
« Reply #5 on: January 31, 2013, 10:50:39 PM »
-Mark.
Mark, as far as I know there have been many 69 origiinal Z/28's with a green tip. What you are referring to (IMHO) are the service replacements that had a green tip and dimple impression that the originals did not have. This topic has been discussed and I'm sure both the green tip with no dimple (impression) and the one shown in this thread are correct. Other words, more than one is correct.
« Reply #6 on: February 01, 2013, 01:25:14 AM »
Yup, there were two (at least) different dipsticks used in production for SB's.
jdv69z
  • 69 RS Z/28 52E
« Reply #7 on: February 01, 2013, 09:16:24 PM »
So here's mine, which I had thought was original? Am I correct?
Jimmy V.
Jimmy V.
« Reply #8 on: February 01, 2013, 10:16:49 PM »
Jim,
It looks identical to the green tipped production unit identified in the Yenko.net link I posted earlier; check it out.   That article also says it should be stamped as such:   "ADD !           ! FULL   USE GM 6041-M QUALITY MS OIL M".
« Reply #9 on: February 02, 2013, 04:46:23 PM »
Gary, I have the flat tipped one as well. I don't know if would be worth everyones time, I have roughly researched this as well when trying to figure out if my dipstick was original. From what I found it seems like the earlier cars had the green tip possibly, and then at one point switched to the flat tip. I don''t know if this was a Z/28 thing only or all small blocks. My 08C norwood car has the flat tip design, which I believe to be original to the car. If those of us who believe they have the original could chime in we might have a rough idea when they switched. I understand there isn't a date code on the dip stick so it may be a tough one to piece together.
rszmjt
« Reply #10 on: February 02, 2013, 04:55:13 PM »
My 06A Norwood RSZ28 has the flattened type.
jdv69z
  • 69 RS Z/28 52E
« Reply #11 on: February 02, 2013, 05:02:19 PM »
Jives with my Oct '68 built Z.
Jimmy V.
Jimmy V.
« Reply #12 on: February 02, 2013, 05:27:02 PM »
 A dipstick research effort would be an interesting endeavor for CRG.
Sort of like the recent bolt markings done last year.
« Reply #13 on: February 02, 2013, 06:08:53 PM »
Rather than dump all the *research* effort on Kurt or another CRG member, there's no reason each poster can't add his information to the list.
Using the previously submitted information, I'd suggest something like the below, distinguishing between 'green tip', and flat style, per the earlier identifying posts here and on Yenko.net (http://www.yenko.net/ubbthreads/ubbthreads.php?ubb=showflat&Number=416817#Post416817).
Each new addition can be added to the bottom of the list by the poster thus we can keep a running tally...
type 1)   flattened handle on end, no PN, no plastic tip, stamped "ADD |           | FULL   USE GM 6041-M QUALITY MS OIL   E".  (E turned 90 deg).
type 2)   light green tip on handle, no PN, no dimple,  stamped    "ADD !           ! FULL   USE GM 6041-M QUALITY MS OIL   M".
Member            Production           Dipstick
                     Plant       Week        Type
69Z28-RS        NOR        09C            flat
JOHNZ            NOR        02?            flat
BULLITT65      NOR        08C            flat
RSZMJT          NOR        06A           flat
jdv69z              ?           10(68)?      flat
« Reply #14 on: February 03, 2013, 09:36:52 PM »
Had a Nov 68 built DZ motor that had the green tip dip stick with the same lettering as JohnZ noted. He has posted that picture many times over the years and I used that picture to compare it to mine and others back in 2008. The later green service replacement dipsticks with the indent/impression have different wording. You will find mixtures of dipsticks on many cars which I'm assuming is due to different suppliers. Have a 67 327 with the same flattened handle (exact) as example shown but the wording is different on the stick. Maybe during 69 camaro model year the flat type was the predominant supplier. :)
jdv69z
  • 69 RS Z/28 52E
« Reply #15 on: February 03, 2013, 10:09:48 PM »
Norwod  10/68
Jimmy V.
« Reply #16 on: February 03, 2013, 11:52:30 PM »
Each new poster should copy this and add his information to the list before posting.
                     Plant       Week        Type
JOHNZ            NOR        02D            flat
RSZMJT          NOR        06A            flat
jdv69z            NOR        10(68)        flat
(add yours here)
« Reply #17 on: February 05, 2013, 02:02:18 AM »
This is the green tipped stick out of the Nov68 built DZ motor. Having the GM 6041 M is the key I believe as judges seem to key on that.
Writing on the stick is the same as what's on the pic supplied by JohnZ.
x77-69z28
« Reply #18 on: February 05, 2013, 04:45:45 AM »
My 05A Z has the flattened type.
« Reply #19 on: February 05, 2013, 12:41:50 PM »
type 2)    green tip on handle, no PN, no dimple,  stamped    "ADD !           ! FULL   USE GM 6041-M QUALITY MS OIL   M".
                     Plant       Week        Type
JOHNZ            NOR        02D            flat
RSZMJT          NOR        06A            flat
68CamaroZ28    ?          11(68)        Green tip
X77-69Z28      NOR        05A            flat
« Reply #20 on: February 05, 2013, 02:36:38 PM »
                     Plant       Week        Type
JOHNZ            NOR        02D            flat
RSZMJT          NOR        06A            flat
68CamaroZ28  NOR        11(68)        Green tip
« Reply #21 on: February 07, 2013, 01:43:36 AM »
firstgenaddict - NOR - 10D (68) - Flat
« Reply #22 on: February 07, 2013, 02:16:41 AM »
                     Plant       Week        Type
JOHNZ            NOR        02D            flat
RSZMJT          NOR        06A            flat
z28z11           NOR         01C            flat
latebuildZ
« Reply #23 on: February 07, 2013, 03:53:20 AM »
Latebuildz   NOR       10C       flat
Hans L
« Reply #24 on: February 12, 2013, 04:04:36 AM »
My 04B '69 Z has the same style as John Z.   Flat tip, same text, 90 deg "E".
'69 Chevelle SS 396 4 Speed
Boston14
« Reply #25 on: February 17, 2013, 12:30:46 AM »
My 11D(68) Norwood  1969 RS/SS 350 Convert has the same stick that John Z has (flat).
boston14
1969 SS/RS 350 Convertible
« Reply #26 on: February 17, 2013, 04:17:55 AM »
(trying to bring the list up to date)...
                     Plant       Week        Type
JOHNZ            NOR        02D            flat
RSZMJT          NOR        06A            flat
z28z11           NOR         01C            flat
Boston14        NOR         11D (68)     flat
Hans L                           04B            flat
LatebuildZ                     Nov68        green tip
LatebuildZ       NOR        10C           flat
firstgenaddict   NOR        10D (68)    flat
« Reply #27 on: February 19, 2013, 05:26:00 AM »
Just a suggestion - it's easier to see trends if the data is organized by build date.
Also, this research is applicable to any 69 SB.
« Reply #28 on: February 19, 2013, 02:30:35 PM »
Re: 69 smallblock V8 (302, 307, 350) Oil dip sticks  (reorganizing per Kurt's suggestion)
type 1)   Flattened handle on end, no PN, no plastic tip, stamped "ADD |         | FULL   USE GM 6041-M QUALITY MS OIL   E ".  (E turned 90 deg).
type 2)   Green tip on handle, no PN, no dimple,  stamped             "ADD |         | FULL   USE GM 6041-M QUALITY MS OIL   M ".
                    Plant       Week           Type
LatebuildZ         ??         Nov(68 )     green tip
68CamaroZ28  NOR       11 (68)        green tip
z28z11           NOR         01C            flat
JOHNZ            NOR        02D            flat
Hans L              ??         04B             flat
RSZMJT          NOR        06A             flat
Where are the LA cars??
Each new poster should copy this and add his information appropriately to the list before posting.
« Reply #29 on: February 19, 2013, 03:02:27 PM »
Added one -
                    Plant       Week           Type
z28z11 (X77)   NOR         01C            flat
JOHNZ            NOR        02D            flat
z28z11 (Z11)   NOR        03D            flat
Hans L              ??         04B             flat
RSZMJT          NOR        06A             flat
jdv69z
  • 69 RS Z/28 52E
« Reply #30 on: February 20, 2013, 03:24:43 PM »
Question: My green tip dipstick does not have the "Use GM...." stamped on it anywhere. Just the add/fill markings. Does that mean anything?
Jimmy V.
69Z28
  • 69 X33D80 Z28
« Reply #31 on: April 05, 2013, 06:47:41 PM »
First week 06A
                    Plant       Week           Type
z28z11           NOR         01C            flat
JOHNZ            NOR        02D            flat
Hans L              ??         04B             flat
RSZMJT          NOR        06A             flat
69Z28            NOR        06A            flat
GaryC
« Reply #32 on: December 12, 2020, 06:06:26 AM »
Added my early LA car:
                    Plant       Week           Type
BULLITT65.       LA.        10B (68)     flat
z28z11           NOR         01C            flat
JOHNZ            NOR        02D            flat
Hans L              ??         04B             flat
RSZMJT          NOR        06A             flat
69Z28            NOR        06A            flat
« Reply #33 on: December 12, 2020, 08:28:38 PM »
I have had probably more than my share of experience with dipsticks.  :)
Red, yellow, gray, brown, etc.  Red one shown is a newer reproduction. Others are original.
john jay 69Z
« Reply #34 on: December 13, 2020, 07:54:14 PM »
Hi All,  its my first time engaging in conversation. I have a green tip dipstick on my  late Sept 69 302
 but mine has 3951576 after -  USE SE ENGINE Oil is mine original
Really enjoy the club
regards
John
« Reply #35 on: December 14, 2020, 03:57:59 AM »
regards
John
Welcome to the CRG, John - Norwood or Van Nuys (LA) production ?
ZLP955
« Reply #36 on: December 14, 2020, 07:50:28 AM »
Mine has the flat tip dipstick, but haven't included that as a data point as it was in a CE-block engine. May or may not be original, depends on what was swapped over.
Tim in Australia.
john jay 69Z
« Reply #37 on: December 14, 2020, 09:55:58 AM »
Thank you Steve,
my car is a Norwood built 3rd week of September
Hans L
« Reply #38 on: December 31, 2020, 02:23:25 AM »
My Z, under Hans L is VN built.  04B.
« Reply #39 on: December 31, 2020, 11:35:47 PM »
The yellow tip is a later service replacement is it not?
John Jay, I believe our great contributor JohnZ had stated what’s on your stick is a later service replacement but lots of questions on some dipsticks.
BillG
« Reply #40 on: January 02, 2021, 12:42:48 AM »
Mabey off topic but, are the metal paint/finishes different on the flat vs colored tipped? Looks like some green tipped stick metal finishes were black?
Bill Garrett
« Reply #41 on: January 02, 2021, 02:52:55 AM »
Yellow is 68 and 69 big block. 70 too I think.  Light red/salmon is 67 big block. The red reproductions are too “red” and should be somewhere between red and pink. I will see if I can find an original and post if I find one. The green tips I have are from original 69 to 72 engines.
« Last Edit: January 02, 2021, 05:52:59 AM by bcmiller »
« Reply #42 on: January 02, 2021, 03:38:23 AM »
Does anyone know what a flat white tip big block would have been for?
« Reply #43 on: January 02, 2021, 03:49:09 AM »
Let me do some checking. I have all the colors written down somewhere. From memory, white dipstick was for 6 cylinder engines mid to late 60s.
« Last Edit: January 02, 2021, 05:06:59 AM by bcmiller »
« Reply #44 on: January 03, 2021, 01:42:53 AM »
Sorry, my comment on your pictured yellow dipstick refers to that one being a later service replacement due to the deep dimple piercing noted on later service replacements.
« Reply #45 on: January 03, 2021, 02:40:26 AM »
I’ve read back where some corvette owners have said their big block had a white tip but no pics and assumed round handle. This was in 68/69 model years.
« Reply #46 on: January 03, 2021, 03:10:34 AM »
You are correct!
I checked the faint writing on the masking tape attached to it. Pulled from a 1972 402 (396) engine. So it’s not the original shape for 68-70. Good eye!
« Reply #47 on: January 03, 2021, 05:26:58 PM »
Checked my 68/69 NCRS judging manual #4 and it states 427 dipsticks have a round handle with white tip but at date 7/22/69 per Corvette AIM went to long angled handle with a flattened finger hold and no plug which was used intermittently with the white tipped dipstick until very late in the model year.
« Reply #48 on: January 05, 2021, 05:46:42 PM »
That’s possible.
Remember the dipstick was added at the vehicle assembly plant. So a BBC Corvette could have been different than other models.
White is correct for L6 at least in 1968 and probably other years. Length is obviously different than SBC or BBC.
Darrel do you have a pic of the white tip one you mentioned? Or length?
« Last Edit: January 05, 2021, 08:43:44 PM by bcmiller »
Dave69x33
« Reply #49 on: May 02, 2021, 02:20:47 PM »
Hello CRG,
I am doing research on dip sticks.  I purchased this NOS stick around 1996 - 1998 from Rick George when he operated Rick's 1st Gen Camaro, while I was restoring my Norwood 05A '69 Z28, VIN 638712.  I am looking for my original dip stick, as I don't recall if it has a flat or round handle.  According to Heartbeat City Camaro (they purchased Rick George's inventory), the green tip sticks they sell now do not have the dimple like the late NOS GM version.  My stick does have the dimple in the handle just above the cap seal.  This stick states "USE SE ENGINE OIL   3951576   M."  The stick measure 19-5/16" from the tip to the top edge of the seal cap.
Does anyone else have the same dip stick with the dimple?
Dave69x33
« Reply #50 on: May 02, 2021, 03:33:58 PM »
Follow up 2nd question...
Heartbeat City Camaro (HBC) list item #EGP-1495 flat handle dip stick replacement for GM 3951576 as the 1st Design, and item EGP-1494 round handle with green tip replacement stick as the 2nd design.
From what I can tell, the 1st Design flat handle design appears to be what was originally installed at the factory on most '69 Camaro small blocks (per Jerry MacNeish certification reports).  Any idea when the  2nd Design was released and if it was only a service replacement dip stick?  My factory parts catalog does not list different part numbers for the two designs.  I wonder if the "M" stamped in the stick of my round handle unit indicates a design revision change?
« Reply #51 on: May 06, 2021, 10:42:36 AM »
Hello CRG,
Dipsticks with the dimple u show are later gm service replacements and are not found on survivor sticks.
john jay 69Z
« Reply #52 on: May 10, 2021, 10:55:42 AM »
Hi Dave,
My oil dipstick is the same as your photos green tip with the dimple and wording "USE SE ENGINE OIL   3951576   M
