Author Topic: 18N536325 V0614MO Block  (Read 4058 times)
nwsgjr
« Last Edit: January 11, 2013, 03:14:47 PM by Ed Bertrand »
Re: 18N536325 MO Block
« Reply #1 on: January 11, 2013, 02:48:08 PM »
The VIN can't be 18N536325 since they didn't produce that many cars at Norwood in 1968. It's probably 18N436325, but either way, it's a restamp.
Seller is sixtyeightmuscle out of Surrey, BC with a buy it now price of $1,100.00
Quote
This is a 1968 Camaro Z28 engine block. It is a standard bore block which measures 4.00 across with the micrometer. The block is is good shape as it has its original main caps and there is no machining anywhere. There was a small repair done by the bellhousing corner, but is not a stress point and is no concern. The block has clean cylinders which should clean up at probably 20 over. The block has been in storage for years and years. Check your cars vin because this block could belong to your car. The main bearing caps are original to the block as well which is vital. The blocks casting is 3914678. The vin number appears to be 18N536325 . The block stamp numbers are VO6I4MO and the date code looks like DF78. Extremely rare block that is almost impossible to find and original ...better yet in standard bore. I will ship to the USA and CANADA. Do your homework as this block can be dropped off at UPS Freight in Bellingham WA 98230 Zip or better can be picked up from that zip code zapped and palleted. In Canada, it can go roadway ground from Vancouver zapped and palleted. Please check phone shipping companies and check your rates yourself. I think its better. ... Goodluck
Don't be fooled by RESTAMPS as there is lots of them on the market......THIS IS A VIRGIN BLOCK ....UNTOUCHED....
This is a super low price for a buy it now at only 11 hundred bucks...... standard ...This will last you all your natural life !
******* I AM GIVING YOU THE OPTION OF ORGANIZING THE SHIPPING OF THIS ITEM FROM THE INFORMATION LISTED ABOVE. IT IS NOT FREE SHIPPING !!!!! BUT FREE PACKAGING ************************
Date code is F 7 8
« Last Edit: January 13, 2013, 06:35:18 PM by Ed Bertrand »
Ed "Bert" Bertrand
email me!
Re: 18N536325 V0614MO Block
« Reply #2 on: January 11, 2013, 05:41:30 PM »
This seller (sixtyeightmuscle) purchased a MO block (18N436532 V0511MO) back in '08...
http://www.camaros.org/forum/index.php?topic=3495.0
« Reply #3 on: January 18, 2013, 05:48:37 PM »
No sale 1-17-13...
Reserve not met = $1100.00
« Reply #4 on: January 26, 2013, 05:12:25 PM »
« Reply #5 on: February 02, 2013, 07:21:20 PM »
No sale 2-2-13...
Reserve not met = $999.99
« Reply #6 on: February 11, 2013, 08:54:48 PM »
« Reply #7 on: February 22, 2013, 01:54:04 AM »
No sale 2-21-13...
