Author Topic: Earliest 3969341 and Latest 3894860 axles  (Read 178571 times)
Re: Earliest 3969341 and Latest 3894860 axles
« Reply #180 on: January 01, 2020, 05:22:29 PM »
Note here from the Chevrolet Dealer Service Information Bulletin dated September 29, 1969.
The first C in the code designates it as a Passenger (car) type axle versus Truck. This is for very late 1969 model year axles and continued into 1970.  Things changed again in 1971. Remember that GM "Corporate" 10 bolt axles were gradually implemented in the early 1970s.
GCS SS350
« Reply #181 on: October 19, 2020, 01:54:58 AM »
Build Date : K208
Housing Stamp : BS1205G2
Num : 3894860NI
Early 1969 SS350
Vin : 124379N561885
Assume Diff, is orignal as matchs protecto Plate Numbers
Has 3.73 posatraction currently & have orignal 3.31 gm gears
If anything else naaded let me now
« Reply #182 on: October 21, 2020, 12:58:48 AM »
Build Date : K208
Num : 3894860NI
Early 1969 SS350
Vin : 124379N561885
If anything else needed let me now
Thanks for your post and welcome to the site.
What we are looking for in this thread is data on cars built the summer of 1969.
I will send you a private message.
« Reply #183 on: January 11, 2021, 04:35:33 PM »
Had someone else send me some data, it is the last one on the list.  C BE 1030G1  - not peened.
This does remain an active topic. I may have a few more to add that were obtained the past few years.
« Reply #184 on: January 13, 2021, 09:18:31 AM »
Updated January 11, 2021
Remember when submitting data - put all of the information requested in ONE POST - PLEASE.
Some notations have been made for C BU axles where the C has been peened. I did not note this on all of the ones listed.
Here is what we have so far.  We need more data points for axle assembly dates between early June and early August.  My apologies if your data was inadvertently missed.
It appears that the 341 casting number started being used in June. It appears that the 3 letter code had started by early August, possibly earlier.
Remember that there was a shutdown for the latter part of July and into very early August.
01C
BM 0124G1
860, casting date A 21 9
06A - 9N665238
BM 0625G
860, casting date unknown
07A - 9N6687XX
BU 0630G2
860, casting date E 26 9
Unknown build date
BE 0708G1
860, casting date D 28 9
Unknown build date possible over the counter/warranty axle
C 107 231 G1 with 7 and 1 peened out, shows C 10 23 G1
341-A, Casting date E 14 9
08E  9N677954
C BS 0805G
341, casting date G 25 9
08C
C BL 0806G1
341, casting date G 23 9
Unknown build week and/or VIN
C BM 0807G1
860, casting date F 24 9
Unknown
No assembly stamp, possible warranty axle
341, casting date F 28 9
08D  9N6745xx
C BU 0818G2
unknown casting number or date
08D
C BS 0820G2
341, casting date H 11 9
08E, 9N677163
C BL 0812G2
341, casting date H 5 9
08E
C BU 0828G2
341, casting date H 13 9
08E
C BU 0828G2
341, unknown casting date
09A - 9N680789
C BU 0828
09A
C BU 0826 or 0828
09C
C BU 0829G1
341, casting date G 31 9
C BS 0829G1
341, casting date H 17 9
09C 9N684457
C BU 0829G1
341, unknown
09C   9N685397
C BU 0910G1
341, casting date I 2 9
C BU 0916        C area is peened
341, casting date I 6 9
C BU 0922G2    C area is peened
341, casting date I 11 9
10A
C BU 0929G1    C area is peened.
341,
C BS 1028G1
341, casting date J 3 9
C BE 1030G1 not peened
341, casting date J 3 9 or J 8 9 (hard to read)
Updated
« Last Edit: June 07, 2022, 08:31:56 AM by bcmiller »
« Reply #185 on: June 08, 2022, 02:33:47 AM »
If anyone can confirm if there is an NF or something else after their axle with a casting number ending in 341 I would appreciate it.
We have found a very early 341 casting that has a -A and might be a test casting.
« Reply #186 on: August 23, 2022, 03:08:34 AM »
Found one listed in a car today. CBU 0815G2 in 9N672588 but can guarantee it’s original.
JST69Z28
« Reply #187 on: October 07, 2022, 07:54:13 PM »
Attached is a photo of my differential date code on a 69 Z28, 07A car,  BU 0624G2 E.  On the diff, it also has 3894860NF, E189, and GM 57 numbers.  Reading through other posts it should have a C in front of the BU but I don't see one.  I'm new to the group and reading through history and adding info.  Hope this helps as you build data.  I really appreciate all of this great info.
JST69Z28
« Reply #188 on: October 07, 2022, 07:58:00 PM »
I forgot to add the VIN, 124379N665447.
« Reply #189 on: October 07, 2022, 08:02:32 PM »
The "C" stamp seems to be as early as August 5th and not used consistently until the later part of August. I have rear ends as late as August 22 with no "C" Stamp present.
« Reply #190 on: January 07, 2023, 07:04:06 PM »
I bought this one today.
Unknown build date or VIN possibly from a Nova
C BS 0909G1
341, G 31 9 casting date
« Last Edit: January 08, 2023, 03:58:44 PM by bcmiller »
« Reply #191 on: January 08, 2023, 03:55:04 PM »
It is fine that is does not have a C in the front.  That started later in the year.
« Reply #192 on: January 08, 2023, 03:57:35 PM »
Updated January 11, 2023
01C
BM 0124G1
06A - 9N665238
BM 0625G
07A - 9N6687XX
BU 0630G2
Unknown build date
BE 0708G1
08E  9N677954
C BS 0805G
08C
C BL 0806G1
C BM 0807G1
Unknown
08D  9N6745xx
C BU 0818G2
08D
C BS 0820G2
08E, 9N677163
C BL 0812G2
08E
C BU 0828G2
08E
C BU 0828G2
09A - 9N680789
C BU 0828
09A
C BU 0826 or 0828
09C
C BU 0829G1
C BS 0829G1
09C 9N684457
C BU 0829G1
341, unknown
C BS 0909G1
09C   9N685397
C BU 0910G1
10A
341,
C BS 1028G1
« Last Edit: January 12, 2023, 10:28:04 PM by bcmiller »
« Reply #193 on: April 04, 2023, 02:24:57 AM »
Found another one. Late 69 Camaro
C BS 1022G1
341 casting
« Last Edit: April 06, 2023, 01:32:20 AM by bcmiller »
boomer632
« Reply #194 on: April 04, 2023, 11:20:40 AM »
Build date 06A X66 396
Casting number 860NF
Assembly stamp BU 1126 G1 E
Casting date K228
69 SS NOR 06A 711 57 57 X66 L78 M22 BU
