Author Topic: Earliest 3969341 and Latest 3894860 axles  (Read 98379 times)
6667ss138
Re: Earliest 3969341 and Latest 3894860 axles
« Reply #60 on: July 07, 2014, 02:53:39 AM »
I think so because I have a LOT of original May dated parts still on my car. I figure they were winding down and using up everything laying around knowing the shut down was coming. Trying to get rid of parts inventory.
According to William there were no cars manufactured at Norwood after July 11th until August 11th.
I will also ad that it would be surprising if they used up "everything" before the shut down so therefore I would assume that there were still parts around to be used up on the early August cars when production resumed on August 11th but that is only a guess.
http://www.camaros.org/forum/index.php?topic=12251.0
Len  KS
69 Z/28 07A X77D80 HO/Blk Vinyl Top, Blk int. born w/drive train, full 3 owner hist, JM certified
69 Z/28 X77 Cortez Silver/Blk int. JM certified
67 SS396 Chevelle 138 Convertible/Red/Blk int.
« Reply #61 on: July 07, 2014, 01:15:33 PM »
6667ss138 -
Thanks for posting the information from your car.  I appreciate it.
1967 RS/SS 396 coupe L35/M40 - 4 generation family project
6667ss138
« Reply #62 on: July 07, 2014, 05:25:13 PM »
6667ss138 -
Thank you Bryon!
Len  KS
« Reply #63 on: July 20, 2014, 04:42:57 PM »
Found this on craigslist.
Darrell Cook
If you have a 65 - 70 Solid Lifter GM vehicle please contact me at    cook_dw@hotmail.com   so I can add your vehicle to my database.
« Reply #64 on: July 21, 2014, 04:09:50 AM »
Thanks Darrell.
Looks like
Build week and/or VIN ?
C BS 1028
341, cast J 3 9 or J 8 9
flyingskibiker
« Reply #65 on: August 10, 2014, 02:34:56 AM »
3894860NF
A239
BU 0128 E
It is in my '68.  So, no '69 build date or VIN...
« Last Edit: August 10, 2014, 02:50:12 AM by bcmiller »
« Reply #66 on: August 10, 2014, 02:51:18 AM »
Looks like 0128 is the date.  You had 0218, so I modified your post so it matches the picture.
Thanks!
« Reply #67 on: February 25, 2015, 01:06:16 AM »
Here's an early 341.
08C CBL0806G1  I don't know the casting date.
« Reply #68 on: February 25, 2015, 01:39:22 AM »
Was the axel code " C BL" the last thing to get stamped ?
It looks like most rear ends the date is gang stamped, but the letters hand stamped?
Also, Kurt do you know the vin of that car?
« Reply #69 on: February 25, 2015, 03:43:54 AM »
Thanks Kurt!  Here is another one.
341 casting number
CBS 0829G1
Casting date H 17 9
Can't verify it is a Camaro axle.  Might be from a 70 Nova.  It was found under a pickup truck.
« Last Edit: February 25, 2015, 04:36:38 AM by bcmiller »
rszmjt
« Reply #70 on: February 25, 2015, 05:38:24 AM »
08E Z28, "341" cast number , BU0828G2
« Reply #71 on: February 25, 2015, 06:52:27 AM »
Just to clarify-
That looks like C BU 0828G2
« Reply #72 on: February 25, 2015, 02:20:42 PM »
Here is what we have so far - arranged by axle date..  We need more data points for axle assembly dates between late June and early August.
06A - 9N665238
BM 0625G
860, casting date unknown
07A - 9N6687XX
BU 0630G2
860, casting date E 26 9
08E  9N677163
C BL 0812G2
341
08E  9N677954
C BS 0805G
341, casting date G 25 9
08C
C BL 0806G1
341, casting date G 23 9
Unknown build week and/or VIN
C BM 0807G1
860, casting date F 24 9
08E  9N677163
C BL 0812G2
341
08D  9N6745xx
C BU 0818G2
unknown casting number or date
08D
C BS 0820G2
341, casting date H 11 9
08E
C BU 0828G2
341, casting date H 13 9
08E
C BU 0828G2
341, unknown casting date
09A - 9N680789
C BU 0828
341, casting date unknown
09A
C BU 0826 or 0828
09C
C BU 0829G1
341, casting date G 31 9
C BS 0829G1
341, casting date H 17 9
09C   9N685397
C BU 0910G1
341, casting date I 2 9
C BU 0916
341, casting date I 6 9 (changed to I 6 9 - could not be J 6 9, J is October)
C BS 1028G1
341, casting date J 3 9
« Last Edit: August 13, 2018, 12:46:46 AM by bcmiller »
« Reply #73 on: February 25, 2015, 02:43:45 PM »
Bryon,
After noticing that I failed to provide you my cast date, I checked some photos of my differential made when I was cleaning it, and found one with the cast date..  G 31 9
Please update the following entry in your data...
09C
CB U 0829G1
341, unknown casting date  G 31 9
« Reply #74 on: February 25, 2015, 02:51:32 PM »
Got it.  Thanks Gary!
