Author Topic: cruise control diagram 68 camaro  (Read 30474 times)
rippin
« on: December 18, 2012, 03:26:41 AM »
    doz anyone have a diagram for parts and connections for a 68 camaro cruise control unit
Re: cruise control diagram 68 camaro
« Reply #1 on: December 18, 2012, 03:10:48 PM »
That info is in the 1968 Assembly Manual. A paper copy is avaiable from most of the vendors, but you can get a PDF copy for free HERE.
rippin
« Reply #2 on: December 19, 2012, 04:02:20 AM »
   i had read a 68 camaro cruse control  uses a lever on steering column , mine has a button under the dash ,which is correct ?enclosed is a pic of mine
« Reply #3 on: December 19, 2012, 04:06:28 AM »
Yep, the first generation Camaro used the blinker lever for the control. HERE'S more info and some pictures. Yours may be an aftermarket system.
rippin
« Reply #4 on: December 29, 2014, 03:13:21 AM »
Back to work on the camaro .now the vacuum with chain  unit on fire wall is the gm part used in 68 as well as the harness under the dash .could it be that only the button under dash is after market ?
big iron
« Reply #5 on: January 04, 2015, 12:01:06 AM »
Post some pictures so we can tell you what you have.
Bob
rippin
« Reply #6 on: January 06, 2015, 11:52:27 PM »
My 68 camaro (which has been in storage un touched for 35 years n in the process of rebuilding last 4 years ) seams to have a factory cruse control on it but although all parts still on it are gm stock including the button arm that go's to turn sig on steering column  but the  different is my button is under the dash next to convertable top switch  .could a person do a option override to have the cruse button set up this way ?
VINCE Z28
« Reply #7 on: January 07, 2015, 02:16:22 AM »
rippin, post some pictures like Big Iron asked over on the Restoration post. He knows alot about the subject.
« Reply #8 on: January 07, 2015, 02:54:47 AM »
I agree.  Pics would help.
« Reply #9 on: January 07, 2015, 10:48:17 PM »
No need to start a new thread. You'll just get the same responses / requests. :)
rippin
« Reply #10 on: January 08, 2015, 01:06:44 AM »
Ok when I get back to some in a few days I'll post more. Pics .yes I have one already on another post . Thanks
rippin
« Reply #11 on: January 15, 2015, 12:42:57 AM »
Here are the pictures of my cruise control on my 68 camaro
rippin
« Reply #12 on: January 15, 2015, 01:20:25 AM »
Can't seem to get any pics to post .frustrated
rippin
« Reply #13 on: January 15, 2015, 02:37:43 AM »
Pics
rippin
« Reply #14 on: January 15, 2015, 03:04:12 AM »
Sorry so many pics ,can't figure out how to remove the extra ones
*Fixed*
« Last Edit: January 15, 2015, 03:19:45 AM by KurtS »
