Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Search
Login
Mild Modifications
Power BRAKE Booster - not Power Steering
« previous
next »
Print
Pages: [
1
Author
Topic: Power BRAKE Booster - not Power Steering (Read 8996 times)
greg1ontheedge
Newbie
on:
July 24, 2006, 08:02:00 PM »
Busy freakin day at work. It's the hose running from the power brake booster to the intake manifold. The Crossram intake manifold doesn't have a recepticle for the hose so what the heck do I do with it??? Sorry, and thanks............
Tweet
Logged
rich69rs
Hero Member
LF7/M35/Z22/Z87
Re: Power BRAKE Booster - not Power Steering
Reply #1 on:
July 24, 2006, 08:48:50 PM »
You might have to drill and tap npt threads for the fitting - assuming that there is a location on the manifold where you could do it.
Logged
Richard Thomas
1969 RS
CRG Member
Reply #2 on:
July 24, 2006, 08:52:38 PM »
Drill a 9/16" hole at a convenient location on the top plate (out of the way of the linkage and plumbing) and tap it 3/8" NPT for a standard manifold vacuum fitting and re-connect your booster.
Logged
greg1ontheedge
Newbie
Reply #3 on:
July 25, 2006, 02:18:39 PM »
Thanks Rich/John. Sincerely appreciate your responses and help. Is there any alternative other than putting a fitting on this thing? If at all possible, I'd really like to avoid doing that.......... Thanks again.
Logged
red69
Member
Reply #4 on:
July 26, 2006, 01:48:54 PM »
My manifold has a fitting boss in the left front corner,on the top plate. I conected both my booster and PVC there. Do you know what the casting date is on your system? Pat
Logged
greg1ontheedge
Newbie
Re: Power BRAKE Booster - not Power Steering PICTURE ADDED
Reply #5 on:
July 26, 2006, 08:37:30 PM »
Thanks for the suggestions. As I said, I'm really hesitatnt to drill a hole in this thing. I've attached a picture so everybody can see the manifold I'm working with. I'm thinking about trying to tap vaccuum from the carbs. I'll be running 2 Holleys with a mild cam so maybe might have enough vaccuum?
Logged
Print
Pages: [
1
« previous
next »
Mild Modifications
