Camaro Research Group Discussion => Originality => Topic started by: Springer Tom on August 17, 2012, 09:06:23 PM
Need the colors for horn relay and the 2 rear emergency brake cable brackets......thanks
which rear emergency cable brackets are you referrign to? the ones that attached to the leaf spring bottom plate? and keep the EB lines away from the wheel? or ??
Yes the ones attached to the leaf spring mounting plates
60% gloss black
