Camaro Research Group Discussion => Decoding/Numbers => Topic started by: ZLP955 on August 08, 2012, 04:40:02 AM
I have access to 2 voltage regulators for my restoration, both 1119515, one is 9A and the other 9C. Not sure which (maybe neither?) is the original, and therefore wondering which date would be more appropriate for an 04A VN car? Since the VR production dates cover the entire month, I'm curious to know if they were produced continuously throughout each month, or only in limited batches/runs - in which case it may not be likely that the 9C-dated part would have got to Van Nuys in time. I'm thinking the 9A is probably the more likely date for this part?
Go with the 9C. VR's were built everyday (literally hundreds a day), so either 9C or 9D would work in your case.
My 67's have the original VR's still and the dates are very close to the tag's build date.....
LOS 4B - VR=7C
NOR 5B - VR=7E
Never checked mine. Where's the date?
Jimmy V.
Pictures of the date location is in THIS (http://www.camaros.org/forum/index.php?topic=388.0;all) thread.
Ed I looked at the pictures in the other thread. What's the significance of the pencil mark Kurt pointed out?
QA check marks. Not seen on all VM's but if you look really hard, you might still see them on yours.
I've never checked mine either; but I just did and it's stamped 8A on a LOS 02C build.
Thanks everyone for your replies - will go with 9C on the car and 9A as a spare.
Thank you sir for the explanation.
[/quote]
Thanks!!
Checked my reg and it's stamped 8F. June '68, correct? Oct '68 build on car. End of '68 production used in early '69 production? It is part no. 1119515.
Jimmy V.
Wow. That's 4 months. Highly unusual.
Maybe it's not original? Pic attached. Could it be 1979? I know it's not been replaced on my watch which started in 1982.
Jimmy V.
Oops! I mean 1978.
Jimmy V.
Jimmy,
Probably original...
Thanks Kurt. Kinda thought so but..........used to think my water pump and clutch were original too, and it turns out they are not. So it doesn't hurt to check.
Jimmy V.
Back in the day... My buddy and I used to troubleshoot electronic & mechanical issues on my 72 Chevy by swapping units and parts from one vehicle to another.
Sometimes stuff just never got returned to the original vehicle. :)
Maybe your vehicle once had a swap partner before 1982?
My 02A car has the original voltage reg. dated 9A Jan 1969.
My 05A car is 9D
My original early 1969 Z28 Van Nuys Camaro
Build Date 1968 09D
Voltage Regular 8J date code
FYI
Voltage Regulator Month Decoding (no "I" is used)
A = January
B = February
C = March
D = April
E = May
F = June
G = July
H = August
J = September
K = October
L = November
M = December
Just checked the date on mine - 9C for a 04B Van Nuys builts Z. Pretty sure it's original...
Just saw this thread got resurrected. Hans, that's great to know your reg is March because your car is so close to mine in build date, and from LOS too. I ended up going with the 9C VR but because it needed a rebuild, I got a Wells solid state unit and plan to rebuild the 9C with the internals of the Wells. Have seen this done before and it allows the base (with numbers and date code) and cover to be retained. So it looks OE and there's no adjustment required!
