Camaro Research Group Discussion => Maintenance => Topic started by: Mike S on June 12, 2012, 12:46:21 AM
I found the cause of the small gas drops on the floor and isolated it to a pinhole in the gas line within the armor and at the 90 degree bend.
I guess it's expected after 45 years. I am looking at the InLine tube replacement and want to first ask if anyone here has used their lines before and your opinion.
Thank you,
Mike,
I have used their fuel pump to carburetor fuel line on a customer's L48. Someone had cut up the original fuel line to install an inline fuel filter. It was a good quality part that fit with no issues.
I used In-Line Tube on my '69 restoration and they were great fit. Had the gravel guard in all the right places too. I also used their brake lines on my car.
Thanks guys...that's good to know. I'll be placing my order with them.
I got my fuel lines from here and they fit perfectly and look factory.
http://finelinesinc.com/catalog/index.php
i used in line tube on my 67 for gas and brake lines and the fit was perfect as well as the appearance.
