Camaro Research Group Discussion => Decoding/Numbers => Topic started by: 1968 rs/ss on June 11, 2012, 01:28:18 PM
hi all i am hoping you can help me
i recently purchased a seqouia green 1968 rs/ss camaro small block
i am fairly sure it is an rs but ss ?
here is the trim tag any info would be gratefully app
if this cant help is there anyway to identify as as ss
01C K404ST
68-12437 LOS 24995TR
712 V-V Paint
The trim tag will not tell if RS or SS. Does it have original motor? If so what is stamped on the engine pad ? Without documents no way to tell for sure but a few clues are;
Plate welded on the frame rail in left rear wheel well for dual exhaust
2 fuel lines for Q-jet carburetor
12 bolt rear end
under hood insulation
hole to the right side of steering column for speedometer cable for Muncie
There are more clues but this will get you started. Check this and look for the engine stamp and get back with that info.
If it's a original car check to make sure the motor, trans, rear end numbers match your VIN numbers, Only 350, 396 motors came in 68 SS's.
Explore this sight, Almost everything you would want to know is already here. Good luck, 68 RS/SS camaros are the best!
VT
A few corrections if I may...
1. Plate welded on the frame rail in left rear wheel well for dual exhaust. That's a 69 only thing. 68's used Rivnuts and even that isn't a deciding factor since dual exhaust was an option on other engines as well.
2. 2 fuel lines for Q-jet carburetor. Again, that's a 69 only thing. All 68's had a single fuel line.
3. 12 bolt rear end. Not a deciding factor. The L30/M20 also had a 12 bolt.
4. under hood insulation. Again, not a deciding factor. Z87 custom interior cars also came with the hood insulation.
The only way to verify a 68 SS is with paperwork or original engine. Post a picture of the engine pad and that will tell you if it's an SS or not.
Other '68 SS clues are listed here... http://www.camaros.org/diffs68.shtml
Dang Ed hope you didn't pass out from all the blood loss in that "red" post. LOL
I did hemorrhage a little!! But I rubbed some dirt on it (http://www.youtube.com/watch?v=J8kMrLx6_aQ) and I'm okay now.
(Man, I CAN'T wait for football to start up again.)
thanks for your help guys unfortunately the original motor is long gone so any more clues or hints would be app
thanks glenn
In that case Glenn, you're kind of stuck. The only other real indicator is the speedometer hole to the right side of steering column for the Muncie transmission. HERE'S (http://www.camaros.org/images/pages/options/firewall_speedo.jpg) a picture showing the Muncie and non-Muncie holes, but if you have an automatic, this won't help.
What's the VIN? I'll look in the database and see if there's anything on the car.
Bummer drag Glenn, Only a hint but Check your hood for the run number, it should be before your build date and a 68.
VT
the no are 12437832587 i guess what sux is i live 14000 miles away from you guys (aussie) the gentleman who i bought it of lives in san jose
the car has multileaf rear springs 12 bolt posi muncie discbrakes proportioningvalve on the left hand side of the frame and he swore on his mother that it was a true rs/ss i paid 16500 for the car at that time our dollar only bought 69 of yours so you see it owes me a bit of money nearly 30grand landed back here i ues i should have some one look at it for me but i was only there for thee days saw the add in hemmings 10 orso phone calls book the ticket and i was of to buy my dream car now it looks like its turned to shit pardon my english getting a little peaved of at the moment thanks guys for your help though i do appreciate it glenn
forgot to mention no hole in the firewall as per pic the dream is coming to a very rapid end
Glenn, check your VIN again. 12437832587 should be 124378N, but you're also missing a digit at the end. 32587 should have 6 numbers.
will do right now
here we go 124378L325887
can i put the guys name and address on here and hopefully a few of you guyss after a few beers might pay him a little visit shattered
Nope. Sorry Glenn. It's not in the database.
However, if you don't have the Muncie speedometer hole in your firewall, then the car either came with an automatic or other non-Muncie transmission. You're going to have to check the transmission and see what the date code and partial VIN is. HERE'S (http://www.camaros.org/images/pages/decoding/trans_muncie_code.jpg) where to look, but it may also be on the top of the transmission. Also check the 12 bolt for the date code and ratio. HERE'S (http://www.camaros.org/drivetrain.shtml#axle) where to look for that.
Don't give up hope just yet. There's a chance your car originally came with an automatic or maybe even the 3 speed transmission. Both of those have the speedometer cable going through the "non-Muncie" hole.
No, it's not a good idea to post names and addresses on the site. This can cause legal issues.
ed i would not do it just angry at the moment are you saying that they made 68 ss camaros in automatic form as well as 3 speed manuals? confused
Yes they did. The L48 engine in 1968 could be had with either the standard M15 3 speed manual transmission (what you got if you didn't order an optional transmission), the optional M13 Borg Warner heavy duty 3 speed manual transmission, the optional Muncie M20 4 speed transmission or the optional M35 Powerglide 2 speed automatic transmission.
kidding...kidding...kidding...
I live across the street from San Jose, CA (grew up there). I'm Italian. I know people... I'll make him an offer he no can refuse! ;-)
lol funny
