Camaro Research Group Discussion => Decoding/Numbers => Topic started by: RJ_RS_SS_350 on July 09, 2006, 02:50:37 PM
Hi everyone, thanks for all the help so far. I was wondering what numbers should be on the master cylinder and brake booster for my 67 01A LOS build with front disc brakes. And do all 67 small block engines use the same booster, metering block, etc. with only the master cylinder changing as the application changes? ??? thanks again, Randy
