Camaro Research Group Discussion => General Discussion => Topic started by: G3 Rods on April 24, 2012, 04:10:43 PM
We are restoring a 1969 Z28 Camaro all numbers matching. And i have the assembly manual but i can't read the layout page for the 302 hood emblem location. If anyone knows i would appreciate your help.
Tyler
Look inside the duct. You will see two punched holes for access. The emblem holes should be centered.
And look at AIM ZL2 B2
I have the assembly manual but i cant read the numbers, if some one knows how far from the back or front of the hood to put them i should be able to figure the rest out.
Tyler
Heartbeat city sells the template. Beware, check the hole location on the emblem studs before drilling. There was a mistake on the template I purchased. The location is perfect though.
Try this; http://www.camaros.net/forums/showthread.php?t=66943&highlight=emblem+template
BTW...did you try what William suggested?
