Camaro Research Group Discussion => Restoration => Topic started by: babaron on January 09, 2012, 06:00:35 PM
is it easy to remove the emblems w/o taking the panel off? ??? if so how is it done?
thx!
anyone?
http://books.google.com/books?id=jEJxVw6L8NoC&pg=PA36&lpg=PA36&dq=how+to+remove+a+camaro+fender+emblem&source=bl&ots=seZTfcb090&sig=E5Wj6jvqvQGSzDaXnGhs0zd6xiA&hl=en&sa=X&ei=7ysMT-_KEarciAK-xf2HBA&ved=0CF0Q6AEwBQ#v=onepage&q=how%20to%20remove%20a%20camaro%20fender%20emblem&f=false
Thank you, that was helpful. It looks like the fenders have to come off. Oh, well...
No they don't. Remove the lower bolts and the one in the door jamb. And the inner fender bolts that are not allowing access. Then stick your paw up there. Not easy but it can be done. This procedure is also for blower motor access. If you don't have much experience working on the sheetmetal, just take your time, examine, and remove/loosen any bolts not allowing you to pull out the lower part of the fender.
