Camaro Research Group Discussion => Decoding/Numbers => Topic started by: discobiscuit on December 23, 2011, 12:55:15 PM
I'm selling the rally wheels of my camaro and was hoping someone could tell me what that code means. I cant really make out the last two letters but they are either FW or FV. Thanks.
FW = 15X7 B-4 1/4 71-up most any GM - are yours 15x7?
From over at Team Chevelle see list below:
http://www.chevelles.com/forums/showthread.php?t=252806
When looking at original GM wheels, they will be stamped around the edges of the valve stem. This is good information to have, because it gives you the size / backspace / production date of the wheel. Below is a list of the available GM information;
XA 14X5 B-3 1/2 67 Chevy II with drum brakes
DA 14X5 B-3 7/8 67 Chevy II RALLY with disc brakes
DG 14X6 67 Camaro & Chevelle with dics brakes
XB 14X6 B-4 3/8 67 Chevelle SS, 68-69 Chevelle with F-70 Tires, 70 Chevelle
XN 14X6 B-3 3/4 68-69 Camaro & Nova with drum brakes. Different shaped outer
AE 14X6 B-4 3/8 70 Chevelle Station Wagon
XG 14X6 B-3 7/8 68-69 Camaro with dics brakes, 68-70 Chevy II/ Nova with disc brakes, 69-69 El Camino without disc brakes. Wider drop center than normal
DE 14X6 B-4 3/8 71-72 Nova & Chevelle, 6 hole wheels
YW 14X6 B-4 3/8 Exactly like XB, may have come on same cars
YJ 14X7 B-4 3/8 69 Camaro/ Chevy II L72- ZL1, 70 Nova
AV 14X7 70-72 Camaro, 71-72 Nova, 6 hole wheel
XT 14X7 L72- ZL1 Non Rally Wheel
YA 14X7 B-4 3/8 69 Chevelle SS Wheel
AO 14X7 B-4 3/8 70 Camaro &69 Chevelle SS Wheel
DB 15X5 67 Passenger Cars with disc brakes.
DF 15X6 B-4 1/16 67-68 Camaro Z28
DC (BIG) 15X6 B-3 1/2 67 Corvette, No other stampings on rim
DC 15X6 B-3 1/2 68-70 Passenger car, 67 Passenger car (early models)
FI 15X6 B-3 1/2 68-70 Passenger car, 67 Passenger car (later models) Rivited instead of welded together
YS 15X6 B-3 1/2 68-70 El Camino
FW 15X7 B-4 1/4 71-up most any GM
AG 15X7 B-3 3/4 68 Corvette (will take 15x8 Beauty rings)
YH 15X7 B-4 1/4 L72- ZL1 Z28 Rally 69 narrow drop center
AD 15X7 B-4 1/4 L72- ZL1 Z28 Rally 68 wide drop center
AV 15X7 70, 71, 73 CAMARO Z28 5 spoke wheel
AZ 15X8 B-4 69-82 Corvette
Here are a few extra notes:
* All the rally wheels made in 1967 have big marking letters, no date code, a little bit different shaped center and slightly bigger holes in the center.
* The 15x7 beauty ring will go on all the 15x6 wheels.
* All the hubcaps interchange with each other.
Yes...they are 15x7.
I also noticed that there are stampings on the inside/center part of the rim next to the bolt holes. On one side of rim is the K 14 and directly across from it on the other side is the 6. The nubmers are the same but of what I've read all stampings on rally wheels are next to the valve stem.
Those are 15x7 Monte Carlo rally wheels, made on June 22, 1974.
