Camaro Research Group Discussion => Restoration => Topic started by: bbd564 on June 20, 2006, 11:14:01 AM
Any one have the dimension for mounting the shift plate on a non console man trans car? I have the hole in the floor pan in the correct spot as I have a console car that I could get the dimensions from. I could work with the dimensions of the actual shift plate on the floor, especially the dimensions from the side of the tunnel to the edge of the shift bezel. Thanks for the help.
