Camaro Research Group Discussion => Decoding/Numbers => Topic started by: HOT3O2 on October 18, 2011, 10:20:12 PM
The build dates for smog pumps start out with a 3 digit "Julian date Code" then the year, and last the plant code. Most of the plant codes I've seen are "1S". (Saginaw). I came across one that the plant code was "1Y". Could someone tell me what plant that was from. Were all 69 Camaro smog pumps made in Saginaw or were there other plants? Thanks
Have you read this report?
http://www.camaros.org/emissions.shtml#usage
It contains info on the pumps.
Thanks Steve, That answers all my questions. You just have to know where to look. I appreciate you pointing me in the right direction.
Great, glad I could assist.
Read the article - and was surprised to see these were on all 69s with a manual transmission. My 69 hard top purchased in 79 didnt' have a smog pump or any signs of one ever being installed - 307 with a 3 speed stick.
Original cars/engines show up on ebay once in a while. Ex manifolds are the same as Z28 and SS350, so those often get removed.
