Camaro Research Group Discussion => General Discussion => Topic started by: IZRSSS on August 05, 2011, 10:56:22 PM
This is probably pretty trivial to most of you but this is one of my biggest pet peeves. I think I've tried just about every conceivable glass cleaner on the market. None of them left my glass free of streaks and smudges, especially on old glass like mine. I think one of the problems is all the detailing chemicals I use that eventually makes its way onto the glass. We'll I think I may have found something I'll stick with. I checked on-line for homemade glass cleaners. This is what I found & it is also the best cleaner I have used to date, not to mention the least expensive;
1/4 cup of vinegar
1/2 teaspoon of liquid soap
2 cups of water
Mix it up & your good to go
If any of you have had good luck with other homemade concoction's or otherwise, please let us know.
Thanx
I'll have to give that a try Marty as is surely don't cost much ;D
I've been using Stoner's glass cleaner for years and never found that to smudge like the windex and such. My wife even started using it several years ago along with micro fiber towels.
Thanks for the tip! I just went through the frustration today preparing for an upcoming concours. I ended up just using rubbing alcohol, but it is definitely lacking. Boy, the inside of the back window is a killer! Thanks again!
Bob
Been using Sprayway glass cleaner for years. Glass shop owners I know use it also. Vinegar solutions have been a home brewed recipe for a long time.
Thanx for the tip Chick & Scott. I'll keep those in mind.
Bob...I have used alcohol & water for years. Trust me, the stuff up top is much better. And yep, thirty yrs ago my body had no trouble turning into a pretzel, not anymore. BTW, I think you are one time zone away from me. Where abouts is the show?
Marty,
Your recipe looks good! The vinegar is acetic, so it would cut road grime, etc. and the soap would degrease.
I use diluted chrome polish. It works great. Of course, it dries white like wax, but it is easy to see and buffs right off.
Equally important is what you use for a wipe. Newsprint (preferably without ink) works great. We got a couple of "end" rolls from our local newspaper several years ago for free. I figure they would charge you for them now.
And Bob, how true! First Gen back windows are hard to clean!!!
Its the Monterey Car Week. Lots of activities including the Historic Races. I'm preparing for the Concours on the Avenue in Carmel on the 16th. Marty, I can sure relate to the thirty years ago!
Bob
Phillip...where you bean??? Good to here from you. Hope everything is going well! I like your recipe as well. It reminds me of what I use on tires...1/4 cup of liquid wax & 2 cups of natural shine protectant. Wipe it on...let dry...buff. Thanx
Good luck w/the show Bob!
Marty,
I'm fine! Sending you a PM...
I started using Stoner's "Invisible Glass" about five years ago, and since my wife took a can and tried it, now we both use it; haven't used anything else since then.
Any brand of wax and protectant? Easy to buff?
Marty thanks for the home brew recipe of window cleaner. And thanks to everyone else for sharing some of your tips and tricks.
Just about any brand of liquid wax will work. I use Mcgr's Natural Shine. I have used Mcgr's (diluted it 2 to 1 w/H20 ) for years but a guy I met at a Santa Fe show told me about the L-wax. Simply hand buff for a few seconds. The wax seems to give the rubber just a little more shine.
Stoner's is sounding better by the minute...
Your welcome Sonny.
