Camaro Research Group Discussion => General Discussion => Topic started by: TX-302 on July 04, 2011, 01:35:24 AM
Trying to locate the engine pad on my 69. Is the VIN engine pad visible/accessible with the engine in the car?
Not real sure on the DZ but on my SB its blocked by the alternator. If you look at an angle between the engine block & the alternator you should be able to see it. A flash light helps.
Good info here...http://www.camaros.org/drivetrain.shtml#PadStamps
69 partial vin could also be by the oil filter on the cast surface. If it's there it will be difficult to see in the car. Search the site, there are several related threads, and some photos.
Thanks for the info guys!
Do you have Jerry MacNeish's book? It answers your question and provides a wealth of other info.
