Camaro Research Group Discussion => Restoration => Topic started by: IZRSSS on June 15, 2011, 03:19:59 PM
What is the correct color for the Rear A/C Compressor Brace bolts & the Vacuum Advance Clip (orange, gray phosphate or black)?
The L-48 vacuum advance line clip is orange - it was on the engiine when it was painted.
Thank you John...I also figured out the A/C brace bolts were on the engine during paint.
Much appriciated!
Much appriciated!
Nope. Those two (painted) intake manifold bolts were removed and discarded, and replaced with two #179841 bolts when the brace was installed; see your AIM, section C60, sheet C7, item #3.
Just in time...was just about to mount the brace.
Thanks John
