Camaro Research Group Discussion => Decoding/Numbers => Topic started by: RJ_RS_SS_350 on June 01, 2006, 05:26:51 PM
Which voltage regulator should I have for my L48 with A/C (C60) and 61 amp alternator (K76)? Thanks, Randy
Randy,
With only a few exceptions (47 amp alternator and C.A.C on the Corvair, 62 amp alternator on all models and transistor ignition on the Chevelle), all cars equipped with the externally regulated alternator from 1962 through the early 70's used the 1119515 regulator. Your 61 amp L48 with C60 would also have used the 1119515.
Thanks Ed
