Camaro Research Group Discussion => Restoration => Topic started by: jeff68 on March 14, 2011, 05:53:07 PM
The 12-bolt rear end cover on my car has quite a few pits in it from rust. Some time ago, I sandblasted the cover then primed & painted it. It looks good, but you can obviously still see the pits throught the paint. I'll be doing a diff oil change when the car comes back from paint, so that will be the time to fix it. I'm trying to decide if it is worth the effort to do 'body work' on the original cover.
So, how are the reproduction covers? HBC claims to have one that is better than everyone else's, but they also want a premium price for it. Has anyone here used one of their covers? I like the idea of a new cover, but don't like the idea of reproductions parts that look like reproductions.
Any opinions or recommendations are appreciated. Thanks.
If it is just a cosmetic issue and not one of needed replacement, I'd vote for leaving the original one in place and skip any "body work" on it. Really comes down to how critical the "appearance" is to you. An original cover with "honest wear" to me is a better piece to look at than a brand new reproduction piece.
Just my 2 cents. Good luck.
Richard
If the car can sit for awhile, spray it with polyester (body shop can easily) body filler, let it dry well, and sand it down. It should fill all the minor rust pits and look like new. Nice to keep the orig. piece IMHO.
Just a suggestion......
Our '67 Z/28 had a pitted rear cover also. I must have rattle-canned filler primer/steel-wooled it 25 times to get it smooth.
I hear you Chick. I usually try to avoid reproduction parts. I guess the rear end cover should be no different. Like Rich said, an "honest" factory-original part is hard to beat or find fault with. The car has always been a Connecticut car, driven 160,000 miles year-round. It's earned every pit on the cover.
The decision has been made to keep the original cover.
How do you tell an original cover from a repo????I bought one off Ebay that is supposed to be an original but it looks to nice to be.
That cover must have been on a LOT of cars from the day. You should be able to find a nice original one at a bone yard or a swap.
Here's a NOS one...
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=110669989305&ssPageName=ADME:B:SS:MOTORS:1123
That doesn't look like mine. It has a notch in the edge and mine doesn't.
Jeff,
Are you sure?? The cutout is usually where the flexible brake hose / fitting bolts, hence the reason for the cutout, so that it mounts "flat" to the housing.
that is a 1970 rear end cover. 69 did not have the notch. it will fit, and probably replaced the 69 cover
My 69 10E car does not have the notch. The brake hose is held by an offset bracket with bolt.
My 69 11D car is like Capt. John's - no notch, offset bracket.
