Camaro Research Group Discussion => General Discussion => Topic started by: TooManyReels on February 27, 2011, 11:07:03 PM
Will a 1967 thru 69 Camaro fit in a 20' Haulmark enlosed trailer with a (PS) side door..I have a limited turn around area in my driveway and anything much bigger then this and I want be able to turn it around to unload it or will my trunk be able to pull it...Its tight right now with my 20' open top trailer, but my little 63 Nova SS does not take up all that much of a foot print on the trialer....I'm gussing it will fit but would like a second opinion...
TMR
Yes. My 69 is in a 20' enclosed Look brand trailer. If it is a flat front you will not have much room for cabinets or storage up front.
Thanks for your help on this..This trailer has a curved nose on it, so I think it will be OK..I found out today that the 1969 camaro is about 16 ft. long which will work great for my application...
TMR
I have been transporting my '69 Z in a 20' Roadmaster without issue for several years. It fits just fine. You will need an escape door on the driver side. Unfortunately, mine side door sill is too high to allow the driver door to open through the escape door in the trailer. You should have seen Jerry Macneish trying to get out of his '68 in my trailer. He made it, but I thought I was going to have to pull him through the driver's window head first.
