Camaro Research Group Discussion => Decoding/Numbers => Topic started by: john302 on January 23, 2011, 05:14:51 AM
Just removed a pitman from a manual steering 68 z and the part number is 3935075a is this original?It looks like it was never removed before and is from a real low milage original car. thanks John
John:
I asked some similar questions over on the Team Camaro site regarding Z ed specific Pitman & Idler numbers - you may want to go to the attached link below and see what many other Z 2/8 owners over there responded with...
The thread was about Z 2/8 ownership and I guess I got them off topic about 8 or 9 pages into the thread with Piman questions...
Randy
http://www.camaros.net/forums/showthread.php?t=182224
John, our pitman arm is "3935075 A" as noted by the camaro.net link Randy supplied.
Same pitman arm on my L30/M20. Hope this helps, RonM.
CRG INFO
"68
The 3908391 long pitman arm was used in 68 Z28's. Other 68 Camaros used the 3935075, 5.25" long, pitman arm (both manual and power steering). The idler arm for 68 was 3917581, 5.25" long."
Chick did this get figured out, My 68 Manual Z also has the 075 & from the .net thread quoted 'others' have reported the same.
My original pitman arm on my Los Angeles built 1968 Z/28 is 3908391. Box is dated A 032 8. Manual steering...Joe
Build date - 12D
Plant - LOS
Steering arm - 391
Box - B 320 7 manual
CRG INFO
"68
Hi Jim, sorry for late reply.... After confirming other Z/28's had the same 075 as mine I never worried or researched further. It seems both 3908391 & 3935075 were used but we know a lot of NOR cars had the 075 for whatever.
Our 68Z trim tag build date 01B
Plant-NOR
Steering Arm 3935075 A
Steering Box manual 3567 or 12/22/67
Found & Visited a Norwood 68 Z28 (FEB68) with the 075 B Pitman Arm
Pitman Idler Steering arms
Darrell 12D LOS man 3908391 replaced
Jim 12D LOS man 3935075
Chick 01B NOR man 3935075 3741383
Jeff 02D NOR man 3935075
Joe 03E LOS man 3908391
ggtsvnv 04A NOR man 3935075
never2 04D NOR man 3908391 3917581
Chick has a short pitman with a long idler.
never2many has a long pitman and a short idler.
Missing the logic so far. :)
We need more data - on all 3 components.
FYI.
Is the different length pitman arm the way they differentiated between regular, and quick ratio steering?
Steering arm - 391
Do you mean pitman, idler, or steering arm?? I thought steering arm, but now I think you meant pitman.
Yeah my fault. I meant pitman.
Realizing we had a terminology problem.
Pitman - attached to steering box
Idler - attached to subframe, mirrors the pitman
Steering arms - connected to the outer tie rod and attached to the hub assembly, we haven't posted data on them, but there are several versions.
Moved it to: http://www.camaros.org/forum/index.php?topic=20581.msg187064#new with some neato data formatting. :)
My Z is an 11D build and has the 3935075 pitman arm.
