Camaro Research Group Discussion => Originality => Topic started by: jeff68 on December 04, 2010, 01:44:30 PM
The front header panel is attached to the fender on each side with 2 bolts with nuts. I have the original bolts, but I do not have the nuts bagged & tagged with them. Does anyone know the correct nuts? Are they flanged? Sorry, my AIM is at the shop and I wanted to try to find the nuts in my pile of hardware. Thanks.
Jeff,
The AIM shows just a standard nut # 9417954.
VT
68 AIM 11-13 A5 shows it as #9417954. AMK shows B-12782 ( 5/16-18 GR5 1/2AF .27TH ) to be their replacement.
This may not be a spot on replacement but the description may help you find your correct one.
The same nut is used on the driver side fender well seal bracket ( 68 AIM 11-13 B2 #9 used for small seal between fender well and body).
Hope this helps.
Bob
Thanks. Does the AIM show a lock washer?
No lock washer shown in either position.
Bob
Thank you very much.
