Camaro Research Group Discussion => Mild Modifications => Topic started by: mopar346 on November 30, 2010, 02:47:59 AM
Title: Compression Opinion
Post by: mopar346 on November 30, 2010, 02:47:59 AM
As I discussed in other threads, I am building a motor for my son's truck. I have been told a few diffent answer to the final compression and was wondering what the collective views are here. It is a 93(ish) 350 4 bolt roller block with forged flat top speed pro pistons and a 64 cc head. Neither the block or the head has had any significant decking in the past.
Thanks in advance, Kevin
Title: Re: Compression Opinion
Post by: BlackoutSteve on November 30, 2010, 05:54:01 AM
Have a look at the cam you're selecting and it should have a minimum recomendation.
I'd go at least 10:1
Post by: mopar346 on November 30, 2010, 12:21:10 PM
I believe it is in the 10s and that is what the cam is calling for, I was just curious if anyone knew what it would be with the above combo.
Post by: Mark on November 30, 2010, 04:51:26 PM
Got any valve relief cuts in the pistons?  If so  and theirs 4 of them then it should be about 9.3 to 1 if not about 9.7 to one assuming a zero deck height.  I've got 1/8" knuckles on my pistons and I'm only pulling about 10.7 to 1.
Post by: mopar346 on November 30, 2010, 05:44:39 PM
Thank you, I believe they have 4 reliefs, I will have them in hand this week end.
Post by: Boston14 on December 01, 2010, 02:22:04 AM
Here's the calculator I use, works great.  http://www.csgnetwork.com/compcalc.html (http://www.csgnetwork.com/compcalc.html)  hope this helps.
boston14
Post by: mopar346 on December 01, 2010, 03:49:24 AM
Thanks, found one at Summit as well, 64 cc heads, with 4 vavle reliefs (+6.1 cc according to summit info sheet), .010 in the hole, .053 compressed gasket, it shows 9.7:1. At 0 deck height it is 10:1. They remaining uncertain is deck height, which I cant measure till the week end.
Thanks folks!
Post by: mopar346 on December 04, 2010, 11:33:18 PM
Checked piston heigth today, .015 in the hole, giving it 9.6:1 compression as long as the head gasket compressed thickness is .053 as I think. The thickness number came from an internet search, does anyone know for sure? It is a regular good quality Fel Pro blue gasket.
Post by: Boston14 on December 05, 2010, 03:49:12 AM
What number Felpro head gasket?   They range from 0.015" to 0.071" thick and have bore diameters from 4.080" to 4.250", giving you a compressed volume anywhere from 3.2cc to 16.1cc. Quite a range and effect on compression!
boston14
Post by: mopar346 on December 05, 2010, 03:53:48 AM
Any way to tell which is which, not that it matters at this point I'm not gonna change anything. Just curious thats all.
Post by: Boston14 on December 05, 2010, 01:26:13 PM
The numbers are stamped into the gaskets.
Post by: mopar346 on December 05, 2010, 01:36:47 PM
Thank you, part number or compressed number?
Post by: BlackoutSteve on December 05, 2010, 11:43:35 PM
Possibly both, but definitely the part number.
Post by: mopar346 on December 07, 2010, 02:28:53 AM
Steve,
Thanks, I was reading a little of you post down under. You're pretty creative and talented. Great job on creating a unique piece.
Post by: BlackoutSteve on December 11, 2010, 04:08:54 AM
Thanks for the compliment.. It helps to be single and a little compulsive!
The stuff I have done is pretty easy. I found that out the hard way :P -by just having a go before deciding to pay someone. :D
Thanks Kevin.  ;)
