Camaro Research Group Discussion => Mild Modifications => Topic started by: mopar346 on November 27, 2010, 10:46:19 PM
Picked up a 67 posi 12 bolt today at the Turkey Rod Run with no axles or brake backing plates. I believe the brakes and backing plates will fit, but what about the axles?? The only reason I ask, is I remember something about 10 bolt tubes being the same as 12 bolt tubes.
Thanks in advance, Kevin
EDIT: info I posted was incorrect
The 10 bolt ones will fit :) just went outside and looked and it was the full size 12 bolt that I was thinking of :( my mistake
Thank you, I thought they were the same. Any thoughts on a donor other than the proper 12 bolt backing plates?
EDIT: My mistake, the 10 bolt brakes will fit.
My apologies for the miss information, it was full size 12 bolts that i was thinking of :(
Very cool so the brakes are the same as I thought. Now if someone knows about the axles I'll be set, picked it up for a song.
10 bolt is 28 spline , 12 bolt is 30 spline
Thanks, but Nova 12 bolt axles would be the same, correct?
http://www.moserengineering.com/axles.html
Yep, not a bad option.
