Camaro Research Group Discussion => Maintenance => Topic started by: sebastien on May 03, 2006, 12:51:02 AM
What type of spark plugs do you recommend for a '68 327 slightly modified ?ac delco r45s ok?
AC45 & 45S were originally for 283 & 307 ( 2BC) in 68.
AC44 was originally for Camaro with 4BC (except 396).
AC44S (extended shield) was for 327 & 350 in Camaro (and Chevelle)
I run AC R45S plugs in all my small-blocks, with and without factory domed pistons; good all-around plug for normal driving, no fouling in my '69 Z/28, which would foul 44's occasionally around town. Autolite 86's also work well for the same normal operation.
Thanks for the info guys.
I forgot to ask;.035 for gaping?
Yup, .035" gap.
thank you kindly!
