Camaro Research Group Discussion => Restoration => Topic started by: Brandan on July 23, 2010, 02:04:50 PM
Title: 67' Speedometer cable firewall hole question
Post by: Brandan on July 23, 2010, 02:04:50 PM
From what I can understand the '67 automatic and Saginaw both used the same firewall hole for the speedometer cable is that right?  I have a pic of my firewall and want to double check.
(http://i221.photobucket.com/albums/dd2/brandansinger/IMG_0201.jpg)
Title: Re: 67' Speedometer cable firewall hole question
Post by: JohnZ on July 23, 2010, 02:59:39 PM
That's correct - every transmission except the Muncie used that speedo cable hole.
Post by: Brandan on July 23, 2010, 04:18:56 PM
Do you know the correct length for the automatic T350 speedometer cable?  I also believe that it routes under the frame kind of like the parking brake cable and turns toward the center of the car.  I want to say that the length is aroun 69 inches.... but not sure....
thanks
Post by: Brandan on July 24, 2010, 04:08:28 PM
Now I read an archived post that the short cable was used 28".  Now I am more confused.  I think the AIM shows the cable goes around the bottom of the chassis (like the parking brake), so I would think that the longer (69") cable would be correct.  Any help on this one.  Also where can I get one?
Post by: JohnZ on July 25, 2010, 04:16:23 PM
The speedo cable routing is shown in your Assembly Manual in UPC 12, sheet A3. The TH350 wasn't available in 1967 - don't know which cable length is correct for it.
Post by: Brandan on July 25, 2010, 09:23:40 PM
Thanks John, you wouldn't know the length of the powerglide cable would you?  I have checked everywhere I can think of........ ???
Post by: Brandan on July 26, 2010, 12:04:15 AM
Quote
thanks John, close but i found it on C3.  Looks like the manual and auto are the same??? ???
Post by: big iron on July 26, 2010, 01:21:12 AM
The 28" cable is for cruise control K30 option. UPC K30 A3  #7- 3919007.
Bob
Post by: Brandan on July 26, 2010, 03:27:17 AM
I am coming up with either a 58 inch or a 69 inch cable, at least narrowed it down somewhat.  Still not sure which one is correct.  I looked at all the parts dealers and with so many different cables it is easy to get confused.  Also Bob thanks for the post.  Unfortunately I don't have cruise.
Brandan-
Post by: rod396 on July 27, 2010, 08:12:41 PM
This is my 1st post, and I have been reading the comments on the speedo cable.................
I have a '68 RS/SS 396 with the Muncie 4 speed. Rolling bare body shell. I have noted the speedometer cable hole per the AIM for the big block,(under wiper motor) but I have no reference to the exact correct length of the cable. Does anybody have any info on this??
