Camaro Research Group Discussion => Restoration => Topic started by: L78 steve on June 03, 2010, 05:07:38 PM
Is there a substitute for the grey putty used on the kick panel to seal it?
Plumbers putty
-Mark.
Is the plumbers putty as sticky and gooey ?
Also known as gray strip caulk. It comes in a box and is somewhat sticky. Similar to the OEM stuff. GM used a LOT of it on my car and I just reused what they put on there.
-Mark.
3M "Strip-Calk", available at any auto body/paint supply store. A similar product can be found at the "big box" stores in the door/window weatherstrip area.
I found that Norton makes a Grey strip caulk, I will give that a look.
