Camaro Research Group Discussion => Originality => Topic started by: GaryL on March 14, 2010, 04:56:54 PM
What is the head marking on the original/correct bolts?
I picked a pair up probably 15 years ago in a junkyard. They are special bolts. The head markings are RBW with 3 concentric circles. The head has a built in washer that slopes down off the hex head. There are also marks of each of the 6 hex head flat spots that go toward the edge of the washer. And it has teeth on the bottom side to grip into the coil bracket. The threaded portion is 0.5" long. Does this make sense? This is for a 68. Anyone else have these on their original 68?
Martin
I have a '69. The same as a '68?
I don't know for sure. I took these bolts off 68 cars that were not Camaros years ago.
Martin
Both '68 and '69 used the same coil bracket bolt (3848408), according to the A.I.M.
Do you have an idea what the head marking is? Thanks.
Gary, I'm sure there were many different suppliers for these bolts. For example, the original coil bracket mounting bolts on my '68 Z/28 have a "T" that bisects the head of the bolt. I believe this "T" identifies the bolt grade, in this case grade 5. On the other half of the bolt head is an anchor!
I have the same tee bolts on all three of my 68z/28.I have also seen E bolts in late 68 and 69 . John
This is the coil braket kit AMK Productions sells for about $4.
Ref. amkproducts.com
67 AIM UPC 6 B5 same #.
I just son't want to end up with Mustang bolts..... ;D
