Camaro Research Group Discussion => Research Topics & Reports => Topic started by: KurtS on March 01, 2010, 10:56:34 PM
The site says: For the 1968 model year, the chromed hood trim for SS396 changed from the simulated finned cooler to a set of simulated carburetor velocity stacks. The early 1968 model year SS350 continued to receive the 1967-style finned hood trim, but the SS350 trim transitioned to the velocity stack trim as the year progressed.
I'd like to have some data to document when the SS hood changed from the finned ornaments to the velocity stacks.
So, looking for data from original 1968 SS cars:
Build date, SS350 or SS396, finned or stacks, which plant.
Results (data in one of the last posts):
SS350 used finned up through Oct. So far, all Nov SS350 have stacks.
SS396 used stacks all of 68.
It would be good to find some LOS SS350 cars built in November to confirm what they used.
Thanks!
04A, SS350, stacks
O5C, 396, Stacks.
VT
03b, ss/rs 350. stacks
04D, SS350, Stacks
05D, SS/RS 396, Stacks
03C. SS396, STACKS
10E LOS car has stacks, 12B NOR car has stacks, both SS396.................RatPack..............
Thanks guys! Tabulated:
SS350
03B stacks
04A stacks
04D stacks
SS396
10E stacks
12B stacks
03C stacks
05C stacks
05D stacks
Looks like we are in need of some early 68 SS data. :)
Kurt, I've had a few 68 SS-350's over the years, but I don't remember the build dates on any of them except one. It was a 09D car and it had fins. It was also an LA car. Don't ask me why I happen to remember this one, because I don't know!
Thanks Ed! Data added below...
SS350
09D fins
03B stacks
04A stacks
04D stacks
SS396
10E stacks
12B stacks
03C stacks
05C stacks
05D stacks
10D = Fins
10D = Fins
Thanks John, 350 or 396?
SS350 Norwood
10D = Fins
SS350 Norwood
Thanks John! Data added below...
SS350
09D fins
10D fins
03B stacks
04A stacks
04D stacks
SS396
10E stacks
12B stacks
03C stacks
05C stacks
05D stacks
Jim Here:
My Car 12E, SS396, LOS, Stacked!
JFW
Jim Here:
Thanks Jim! Data added below...
SS350
09D fins
10D fins
03B stacks
04A stacks
04D stacks
SS396
10E stacks
12B stacks
12E stacks
03C stacks
05C stacks
05D stacks
03A.....NOR....SS350.....Stacks
Dan
03D NOR SS350 Stacks
SS350
09D fins
10D fins
03A stacks
03B stacks
03D stacks
04A stacks
04D stacks
SS396
10E stacks
12B stacks
12E stacks
03C stacks
05C stacks
05D stacks
Thanks guys!
Kurt, I'm wondering if we should go back and ask everyone who responded whether their Camaro is a Norwood or LA car? Would it make a difference?
nov build I think it's 11b 350 stacks
Grampz -
Would you please verify the build date? Thanks in advance!
Yes, the plant will make a difference. But only on the cars in the transition timeframe.
Grampz, which plant?
It looks like we really need data on cars from the first 3 months of 68 - Sept, Oct, and Nov.
Also be interesting to have some more early 396 data to confirm that they actually used stacks at the beginning of 68 production.
Having a post with a summation every other post takes up a lot of space. No biggie, but don't be offended if I delete or edit down some of the older summation posts. :)
Thanks guys!
Kurt, mine is the 04A 350, stacks, below. It's a norwood car.
SS350 10B FINS...
Pic on other site under my profile, 1st Generation RS/SS
sorry...10B SS350 fin and LOS car
Kurt, vin to this car sent to you.............. 09E NOR 8N319*** SS396 has stacks....................RatPack.......................
As Troy reminded me, the documentation shows the 396 was supposed to have stacks from the start of 68. So far, the cars support this.
So, we're back to the original question: when did the SS350 transition to the stacks? It looks like Oct-Nov timeframe, but the plants may have different timing. More data will help tell the story. :)
SS350
09D fins LOS
10B fins LOS
10D fins NOR
11B stacks NOR
03A stacks NOR
03B stacks NOR
03D stacks
04A stacks NOR
04D stacks
SS396
09E stacks NOR
10E stacks
12B stacks
12E stacks
03C stacks
05C stacks
05D stacks
Thanks guys!
the car is in storage about 10 miles out in the country . I will get it asap. It is a norwood build
kurt, mine is a norwood built car also 03b
11E norwood 350 - stacks
Thanks, slowly narrowing it down and confirming. ;)
SS350
09D fins LOS
10B fins LOS
10D fins NOR
11B stacks NOR
11E stacks NOR
03A stacks NOR
03B stacks NOR
03D stacks
04A stacks NOR
04D stacks
SS396
09E stacks NOR
10E stacks
12B stacks
12E stacks
03C stacks
05C stacks
05D stacks
ss350 do not remember the exact build date,But I know it was an early build. It has Finns
Sorry it was also a Norwood built car
Do you know what the VIN was? I can guess the date from that.
ss350 vin # 124378N325427 Fins
I know where there is an orig. one owner SS 350 that has fins. I Think it an oct build with a white Trim tag.
SS350
09D fins LOS
10B fins LOS
10B fins NOR
10D fins NOR
11B stacks NOR
11E stacks NOR
03A stacks NOR
03A stacks NOR
03B stacks NOR
03D stacks
04A stacks NOR
04D stacks
SS396
09E stacks NOR
10E stacks
12B stacks
12E stacks
01D stacks LOS
03C stacks
05C stacks
05D stacks
From the information compiled so far, it looks like the ornaments were changed to the "stack" design for the L48's shortly after the drawing in the AIM was changed on 11-6-67.................RatPack...................
Thanks! I added it.
There's a large disconnect between what happened in the plant and when AIM drawings were done. But here is does seem the timing was about the same.
Oct 350 cars have the fins, Nov cars have the stacks. It will take more data to confirm and improve the resolution (i.e. what week).....
09D Los 68 RS/SS FINS
07C Norwood 68 SS/RS 350 Stacks
04B ss396 stacks
I was able to confirm the car 11B Norwood RS/SS 350 with stacks. I can provide additional info if needed
11A NOR, SS 350, Vin 124378N340537, stacks
Thanks Jeff! That's a key piece of data for this discussion. And welcome to the forum!
SS350
09D fins LOS
09D fins LOS
10B fins LOS
10B fins NOR
10D fins NOR
11A stacks NOR
11B stacks NOR
11E stacks NOR
03A stacks NOR
03A stacks NOR
03B stacks NOR
03D stacks
04A stacks NOR
04D stacks
07C stacks NOR
SS396
09E stacks NOR
10E stacks
12B stacks
12E stacks
01D stacks LOS
03C stacks
04B stacks
05C stacks
05D stacks
SS 350
07D Stacks NOR
I no longer own the car but it was a NOR O2B 68 396 car and it had stacks.
Thanks! And I added a 10C SS350 car to the data.
11c ss396,stacks
08E Norwood SS350 = fins
Wow, very cool detective work. I have a 03C ss350 NOR =stacks. I've havd plenty of people tell me I had the wrong louvers. All I knew was that late build 350's had stacks, now I can tell them which month it changed.
10D LOS SS396/325 (p552 chassis date) stacks
Thanks! Updating the results:
SS350
08E fins LOS
...........................<cropped>
SS350
08E fins LOS
You almost got it, Kurt... :)
Geesum, this shouldn't be that tough.... Fixed. Thanks!
SS350
08E fins NOR
09D fins LOS
09D fins LOS
10B fins LOS
10B fins NOR
10C fins NOR
10D fins NOR
11A stacks NOR
11B stacks NOR
11E stacks NOR
03A stacks NOR
03A stacks NOR
03B stacks NOR
03C stacks NOR
03D stacks
04A stacks NOR
04D stacks
07C stacks NOR
07D stacks NOR
SS396
09E stacks NOR
10D stacks LOS
10E stacks
11C stacks
12B stacks
12E stacks
01D stacks LOS
02B stacks NOR
03C stacks
04B stacks
05C stacks
05D stacks
I can now say vin 124378L333691 stacks, SS350.
'68 SS/rs 350 01A NOR...stacks
Sorry for being late into this post but, I'm a newbie...
SS 396
08D Nor - Stacks
Nice, an early 396 car.
Updating:
SS350
08E fins NOR
09D fins LOS
09D fins LOS
10B fins LOS
10B fins NOR
10C fins NOR
10D fins NOR
11A stacks NOR
11B stacks NOR
11E stacks NOR
01A stacks NOR
03A stacks NOR
03A stacks NOR
03B stacks NOR
03C stacks NOR
03D stacks NOR & LOS
04A stacks NOR
04D stacks
07C stacks NOR
07D stacks NOR
SS396
08D stacks NOR
09E stacks NOR
10D stacks LOS
10E stacks
11C stacks
12B stacks
12E stacks
01D stacks LOS
02B stacks NOR
03C stacks
04B stacks
05C stacks
05D stacks
Stacks were all made by Master Cast in Howell Michigan. Out of business now.
V.C.S.
Thanks!
I thought they were bought out by Alpha-Tech? I doubt they still have the dies though.... :)
03A Nor SS 350 stacks
68 SS 396 L78 - 01A stacks
Updating:
SS350
08E fins NOR
09D fins LOS
09D fins LOS
10B fins LOS
10B fins NOR
10C fins NOR
10D fins NOR
11A stacks NOR
11B stacks NOR
11E stacks NOR
01A stacks NOR
03A stacks NOR
03A stacks NOR
03A stacks NOR
03B stacks NOR
03C stacks NOR
04A stacks NOR
04D stacks
07C stacks NOR
07D stacks NOR
SS396
08D stacks NOR
09E stacks NOR
10D stacks LOS
10E stacks
11C stacks
12B stacks
12E stacks
01A stacks
01D stacks LOS
02B stacks NOR
03C stacks
04B stacks
05C stacks
05D stacks
12B Los SS350 L48 Stacks
68 SS350, 03C stacks NOR
10d nor l48 1968. fins
10D LOS SS350 (8L309348) = fins
Updating:
SS350
08E fins NOR
09D fins LOS
09D fins LOS
10B fins LOS
10B fins NOR
10C fins NOR
10D fins NOR
10D fins NOR
10D fins LOS
11A stacks NOR
11B stacks NOR
11E stacks NOR
12B stacks LOS
01A stacks NOR
03A stacks NOR
03A stacks NOR
03A stacks NOR
03B stacks NOR
03C stacks NOR
03C stacks NOR
04A stacks NOR
04D stacks
07C stacks NOR
07D stacks NOR
SS396
08D stacks NOR
09E stacks NOR
10D stacks LOS
10E stacks
11C stacks
12B stacks
12E stacks
01A stacks
01D stacks LOS
02B stacks NOR
03C stacks
04B stacks
05C stacks
05D stacks
I hate to do this but I think this is going to snow ball... :o
Has anyone noticed there are two types of SS Stacks??? One my cars I have a set where the square stacks are chrome all the way to the base and another car where the chrome only goes about 1/4" down... I'll have to post photos later... but I think both have the correct part numbers...
I just found this site. Don't know if you're still compiling but mines a 68 ss350 01A NOR stacks.
[/quote]I just found this site. Don't know if you're still compiling but mines a 68 ss350 01A NOR stacks.
Welcome aboard there blueSS350. Just remember that when submitting information to this part of site, that it means you can confirm your car came originally this way. If you bought it restored there is no way to confirm it is authentic. You will find these replies invaluable to cronical when changes occurred. Hope you get as much enjoyment and information as I and others have and feel free to ask about things that affect your cars accuracy. Again, glad you found the site. there is a wealth of info and some real super Camaro fans here.
Can you post a photo illustrating the differences?
I have looked at the stacks I have and can not understand whether the difference you speak of it a difference in the black paint application or a different design.
Sounds like paint. I have a set of what I think are 68 fins (as opossed to 67 fins) that have a drain like the 68 stacks. I do not have any 67's or Nova's to compair.
Anybody have knowledge of a differance, or a picture of the bottom of 67 fins?
VT
Orig stacks have a flat silver paint on the base inside the stack area....I have several old nos ones that shows this......
Is this what you're talking about Ed?
(https://lh3.googleusercontent.com/-8Bm8JQrueTY/Us-kAFUAviI/AAAAAAAAGJc/65VFzg6jPJs/w912-h608-no/100_0291+-+Copy+-+Copy.JPG)
exactly.....thanks james
Here is what I have. Top photo = Original, Bottom photo = NOS (still in box).
Bob
Do they appear to have silver paint in the area or is it a textured surface?
It also looks as though the matte silver comes all the way to the top on the outside of the stacks, is this correct?
BTW the inner black out in the bottom of the stacks appears to be anodized aluminum in the originals, are the NOS ones the same?
The outside of the stacks are painted matte silver right up to the top of the stacks. The insides are chrome plated. The base around the stacks are also chrome plated. It's difficult to capture in a photo but there is just a very small amount of overspray where the matte silver meets the chrome plating at the base of the stacks.
Hope this answers your questions.
Bob
10D 396 LOS Stacks
01C NOR 396 stacks
The reproduction Hood stack frames are very nice however the components when inspected with a close eye are off.
In order to make the repros look correct they need to have the areas around the stacks painted silver,
The backers in the originals are Black anodized the repros are black vinyl over aluminum or stainless.
Black anodizing isn't really black it is more of a Deep Purple color.
The wire in the original screens is .040 Aluminum the Repros use .035 Stainless.
(https://lh3.googleusercontent.com/-fdeb5iPFGjE/VH8id0YyItI/AAAAAAAAMto/hbrgi_rktCo/w867-h578-no/SS_Hood_stacks2%2B092.JPG)
(https://lh5.googleusercontent.com/-kx8L56Wrnsg/VH8kffOo-zI/AAAAAAAAMuc/BwNK2oZ5nkA/w867-h578-no/SS_Hood_stacks%2B093.JPG)
(https://lh6.googleusercontent.com/-bl9GAwxWVm0/VH8kewLvGJI/AAAAAAAAMuY/nMNs42eWAJM/w867-h578-no/SS_Hood_stacks%2B095.JPG)
(https://lh5.googleusercontent.com/-XTtZBgl1U4M/VH8lRlrbXuI/AAAAAAAAMvE/FzHmo9eQD0k/w771-h578-no/69_SS_conv_12C_nov2014%2B171.JPG)
(https://lh4.googleusercontent.com/-PmejIGmXrJA/VH8k7zQVT_I/AAAAAAAAMu0/5eHnD9uKSRU/w867-h578-no/SS_Hood_stacks%2B016.JPG)
(https://lh3.googleusercontent.com/-tJIV9v0rEV4/VH8lRWv257I/AAAAAAAAMvA/x2DLgxb9FA4/w771-h578-no/69_SS_conv_12C_nov2014%2B175.JPG)
(http://)
(http://)
hmmm....never noticed this before. Here's what I have. First pic is nos, 2nd pic is good used. Wether it is original production line or not I can't be sure.
But it certainly is paint, looks like a dull aluminum.
(http://members.iinet.net.au/~dream/images/crg/hoodstack/nos.jpg)
(http://members.iinet.net.au/~dream/images/crg/hoodstack/goodused.jpg)
06A Norwood 396 stacks
Update:
SS350
08E fins NOR
09D fins LOS
09D fins LOS
10B fins LOS
10B fins NOR
10C fins NOR
10D fins NOR
10D fins NOR
10D fins LOS
11A stacks NOR
11B stacks NOR
11E stacks NOR
12B stacks LOS
01A stacks NOR
01A stacks NOR
03A stacks NOR
03A stacks NOR
03A stacks NOR
03B stacks NOR
03C stacks NOR
03C stacks NOR
04A stacks NOR
04D stacks
07C stacks NOR
07D stacks NOR
SS396
08D stacks NOR
09E stacks NOR
10D stacks LOS
10D stacks LOS
10E stacks
11C stacks
12B stacks
12E stacks
01A stacks
01C stacks NOR
01D stacks LOS
02B stacks NOR
03C stacks
04B stacks
05C stacks
05D stacks
06A stacks NOR
Thought I would add some input to this topic. 03D L78 Stacks
But the areas between the stacks are not paint or should I say there no signs of having had paint. Wire is like James mentioned. 0.040"
(http://i1310.photobucket.com/albums/s649/cook_dw/1968%20Rallye%20Green%20L78%20Camaro/IMG_3818_zpslxtdqqlb.jpg) (http://s1310.photobucket.com/user/cook_dw/media/1968%20Rallye%20Green%20L78%20Camaro/IMG_3818_zpslxtdqqlb.jpg.html)
(http://i1310.photobucket.com/albums/s649/cook_dw/1968%20Rallye%20Green%20L78%20Camaro/IMG_3819_zpskjckmhh4.jpg) (http://s1310.photobucket.com/user/cook_dw/media/1968%20Rallye%20Green%20L78%20Camaro/IMG_3819_zpskjckmhh4.jpg.html)
(http://i1310.photobucket.com/albums/s649/cook_dw/1968%20Rallye%20Green%20L78%20Camaro/IMG_3825_zpsnnrobmw7.jpg) (http://s1310.photobucket.com/user/cook_dw/media/1968%20Rallye%20Green%20L78%20Camaro/IMG_3825_zpsnnrobmw7.jpg.html)
(http://i1310.photobucket.com/albums/s649/cook_dw/1968%20Rallye%20Green%20L78%20Camaro/IMG_3827_zpslyeojjrp.jpg) (http://s1310.photobucket.com/user/cook_dw/media/1968%20Rallye%20Green%20L78%20Camaro/IMG_3827_zpslyeojjrp.jpg.html)
(http://i1310.photobucket.com/albums/s649/cook_dw/1968%20Rallye%20Green%20L78%20Camaro/IMG_3826_zpsmzhzc4f1.jpg) (http://s1310.photobucket.com/user/cook_dw/media/1968%20Rallye%20Green%20L78%20Camaro/IMG_3826_zpsmzhzc4f1.jpg.html)
(http://i1310.photobucket.com/albums/s649/cook_dw/1968%20Rallye%20Green%20L78%20Camaro/IMG_3820_zpshrlszx0v.jpg) (http://s1310.photobucket.com/user/cook_dw/media/1968%20Rallye%20Green%20L78%20Camaro/IMG_3820_zpshrlszx0v.jpg.html)
(http://i1310.photobucket.com/albums/s649/cook_dw/1968%20Rallye%20Green%20L78%20Camaro/IMG_3821_zps9axlnz1s.jpg) (http://s1310.photobucket.com/user/cook_dw/media/1968%20Rallye%20Green%20L78%20Camaro/IMG_3821_zps9axlnz1s.jpg.html)
(http://i1310.photobucket.com/albums/s649/cook_dw/1968%20Rallye%20Green%20L78%20Camaro/IMG_3822_zpsjsavoios.jpg) (http://s1310.photobucket.com/user/cook_dw/media/1968%20Rallye%20Green%20L78%20Camaro/IMG_3822_zpsjsavoios.jpg.html)
(http://i1310.photobucket.com/albums/s649/cook_dw/1968%20Rallye%20Green%20L78%20Camaro/IMG_3823_zpsqjomf482.jpg) (http://s1310.photobucket.com/user/cook_dw/media/1968%20Rallye%20Green%20L78%20Camaro/IMG_3823_zpsqjomf482.jpg.html)
(http://i1310.photobucket.com/albums/s649/cook_dw/1968%20Rallye%20Green%20L78%20Camaro/IMG_3828_zpsv2nfwait.jpg) (http://s1310.photobucket.com/user/cook_dw/media/1968%20Rallye%20Green%20L78%20Camaro/IMG_3828_zpsv2nfwait.jpg.html)
(http://i1310.photobucket.com/albums/s649/cook_dw/1968%20Rallye%20Green%20L78%20Camaro/IMG_3829_zpss8b8dcvc.jpg) (http://s1310.photobucket.com/user/cook_dw/media/1968%20Rallye%20Green%20L78%20Camaro/IMG_3829_zpss8b8dcvc.jpg.html)
That's my observation also.
11A LOS SS396 (8L311330) = stacks
I think I may have a retraction on the green cars original stacks. While digging out the original smog system I came across these and I now believe these to be original to the green car..
(http://i1310.photobucket.com/albums/s649/cook_dw/1968%20Rallye%20Green%20L78%20Camaro/IMG_1199_zps48o4aiek.jpg) (http://s1310.photobucket.com/user/cook_dw/media/1968%20Rallye%20Green%20L78%20Camaro/IMG_1199_zps48o4aiek.jpg.html)
(http://i1310.photobucket.com/albums/s649/cook_dw/1968%20Rallye%20Green%20L78%20Camaro/IMG_1198_zpsz3ifbu1z.jpg) (http://s1310.photobucket.com/user/cook_dw/media/1968%20Rallye%20Green%20L78%20Camaro/IMG_1198_zpsz3ifbu1z.jpg.html)
(http://i1310.photobucket.com/albums/s649/cook_dw/1968%20Rallye%20Green%20L78%20Camaro/IMG_1200_zpscxzp5ai2.jpg) (http://s1310.photobucket.com/user/cook_dw/media/1968%20Rallye%20Green%20L78%20Camaro/IMG_1200_zpscxzp5ai2.jpg.html)
Those are in great condition, wash them and a little chrome polish. the black anodizing doesn't appear to be thin at all.
You say "black anodizing." You mean it's not paint? I was going to fluff mine a little. They look just like Darrell's, but my black area is flaking a little more.
...and when you answer that James, please include if the same treatment was used on the vinyl top(69)mouldings?
The backer plates (behind the wire grille) are black anodized originally (LEFT), the reproductions use a black paint or black vinyl (RIGHT)
(https://lh3.googleusercontent.com/iuPoM_4fn0qKNrOgqKhelsCiX26AKyZFBWYotOWbyYY7KEhVd9c_DUq-RA8i644yefJuUqAWQW_23DGhq42lhDCpXBTaRyy9v0Gb8g8rALOlgiONbW1lz0giN7Q-Gez1s8kC3pvggYV2u4LI-45JYmf60P_FJ6y4SFjTySzGNUkjXNOcaI4o4hpA2ngmKmO08HZ1hLmXMvf-QBL2TCWB5ZPO2CQWjNB2CzwgD69LjjYhhlIgfFXr1kyrRiArn2-bTCVOXMtCXJtZ4HyCwjpA2PvgKdd5RbNF74xLi3OOohoEqViVv5KjSMphbHqqXXVqxgjeKGEW-wgs9xlEmr7eaAVNfCiiEec5IEkAS_QFGh0rx5o2wuLi-ftCPlDiTiy77hJY1-wsaCAYCr6RSktOQrVrp0IQ0N-HZT0zFnwbfmDp_MOqTJVJhjpw1wLLQKk2U24ig7UQgoVQgpGoq7yuF_ygN1mOongVFlaUTlV9VC27y4amNYh0mkmhDZ6QbU2xb5s4BoazpJ6yp1uOJaRrPgMtXAG6EmKC6zADjrqdxQCxzELuA2D3rZ6XD-F_7rpFzWvt=w1195-h896-no)
The black in the actual frame is black paint, the silver is silver paint.
Reproductions do not have the silver paint.
The one on the LEFT is the complete reproduction assembly
The RIGHT is the reproduction frame with the silver paint done, using original anodized backers and the original "screen".
(original screen is .040 aluminum wire the repro is .035 stainless)
(https://lh3.googleusercontent.com/z4Jj5DvxvWpAQUyVOAWTcl3_maSfKZUpeFBCBDjw2AnlmQj0buZ2OivBHXq7zy6bHQpS2Xz-FWly8XgdDBJwfcHdvv_ipA-YJID7efKbgJ2Gqc4lLpgzcrNvnJLInz0nhkIFRAo-IT5I0GYaY8mrTCLUUk3eUKsSgi5p0fmLcXRnxsX2nMasheMr2BXCwOOmL7HFbA1dnY7RK3BOGYerCqYUw1EaJaIPJPh_IBjRk9qWkQJF1wYr37ptK55vuNnXE80WU-sGmuRo-U1vA22PMcAYvhwkuFMuCxM88tbDXUJOGCA1Zy_t0tkxcipdyLS3pX5v-WTWMSmvbef3vn9YtlWhXqnEmvI0RzvrJ6eEq-uuKGyMC5LfomEfwJAPKZC4C06NWKa9RheZKoV6joiT3ggIutd4IUcGMngN0JMKI7XwaEWvbGbweCjqOeFVmQNp7zB4cIL-1tSrHQ_Ha2DPvPMuI7AqO16RBXBV2QZEoDnMn6GHyMBi6jc9XEynYfnZ95Xbmf-BaBQlL0XrwPoYBeKE8kxrWL_59ed3dQ4x1vDu3E4MTUJ40mymA6josI3ycG1I=w1259-h840-no)
On the car -
(https://lh3.googleusercontent.com/IqCSgVrXqmV_nEVxjIEcjqt1i2zGrzMvt_duWKJ0RSyi8U8dYS6st3B3VpUmTa9WdPAHQPuaxqmYbX5dbXdh4453Et2JgJ7GTDGv-2beGNvo3bS5eE7xuCvfuYmw7m_-j6SFjl6g1ReJxVgHQZBaoTGIiSCqdeWZa3gVpZuyRf4Y0Ukrqggiuue7OFZouHMPXR8JSRGScoNMhIRuJJcfQaSvh-_GONTbTXXe9siac0c0a5E36VrqO46fJSx9VM6EqLFpLvx292ihhJbCBzW0YYuR2rJCFKiieYgO4pC8t0Esqd0Kc1FIY07vKjzEXtEFxpRz4Wx6fY79lLk0VnJ4mQ5spL8L_oTn6RDD3hZWSoE60BlivBkn9vD_eu7-VG3XWOnxx_k8aZ2IqOEYRDIsrdghlyGFhFLkzMxlhFXf8Zd46mG2X0CQB5xKAqVYueExLz9dsI-2NfOSJIfgut_V0tyLJPiMRcdpfT0NjtE1noS5rWtxLWGvp6BWiT0yWOyMd-YjBe9Ik2LEHT_2mvkeZYIg2CJTrRGYxbG5dhKU4_6J0DL5QOtuUHJyAfobiLEozUfu=w1259-h840-no)
Excellent explanation James. Thank you. So you are also saying that the center had silver paint, not just chrome? Wow, two things learned. I don't see any evidence of silver paint on my originals. They've never been removed from the hood. I'm about to do that so I can paint.
edit:
I just looked at some pics of mine. I'll have to look at little closer when I get home, but I do see some potential silver paint. I don't know if it's just the flash or not, but it doesn't look like any anodizing is left. I just haven't looked closely at the stacks for quite a while.
(http://i1164.photobucket.com/albums/q573/SgtHawkUSMC/69%20Camaro%20SS396%20L34/69%20Front%20End%20Sheet%20Metal/20141016_210712.jpg) (http://s1164.photobucket.com/user/SgtHawkUSMC/media/69%20Camaro%20SS396%20L34/69%20Front%20End%20Sheet%20Metal/20141016_210712.jpg.html)
(http://i1164.photobucket.com/albums/q573/SgtHawkUSMC/69%20Camaro%20SS396%20L34/69%20Front%20End%20Sheet%20Metal/20141016_210428.jpg) (http://s1164.photobucket.com/user/SgtHawkUSMC/media/69%20Camaro%20SS396%20L34/69%20Front%20End%20Sheet%20Metal/20141016_210428.jpg.html)
Aren't the '68 and '69 SS hood ornaments different from one another?? (not that I know anything about them, but I think I've read that before ).. :)
Yeh Dave, I think you are confusing 68 vs 69. that is the point of the thread I think? That both years are identical except the silver paint on the 68's? If that is not right, someone will surely straighten me and Gary & Dave out.
Ah, sorry about that. I thought the difference was just finned vs. stacks. I didn't realize there were also differences between stacks. Thanks.
Both are identical 68 & 69.
The assem man has the location of the seal changing in april of 69 only difference.
Bentley, .. i suppose our old/bad memories have bit us again.. :)
Rats!
Ok I have a retraction of my previous retraction.. Is that possible?? Anyways I was out in the garage tonight and cleaning up the silver painted louvers in preps of installing when I happen to notice they were both the drivers side.. I thought; hmmm thats odd.. Looked at the boxes and sure enough both drivers.. SOOO with no other options the ones on the car are indeed the originals without the silver paint.. Just goes to show look everything over and verify before posting or making comments..
Nothing like replying to a 7 year old post - looks like you guys solved a mystery I'd been wondering about, but I'll add anyway - Kurt, this makes 3 of the same on the list:
68 SS350 10D NOR - fins
It looks like that may have been the last week of fins on the 68 350, at least at NOR.
No worries, more data is good. :)
02D NOR SS396 (8N386525) = stacks
Kurt,
Been off here for a while - Got married and had kids...just starting to find some time to get back involved :-)
SS396 12D LOS = Stacks
O2C Stacks LOS
SS/RS 396
Update.
SS350
08E fins NOR
09D fins LOS
09D fins LOS
10B fins LOS
10B fins NOR
10C fins NOR
10D fins NOR
10D fins NOR
10D fins LOS
10D fins LOS
11A stacks NOR
11B stacks NOR
11E stacks NOR
12B stacks LOS
01A stacks NOR
01A stacks NOR
03A stacks NOR
03A stacks NOR
03A stacks NOR
03B stacks NOR
03C stacks NOR
03C stacks NOR
04A stacks NOR
04D stacks
07C stacks NOR
07D stacks NOR
SS396
08D stacks NOR
09E stacks NOR
10D stacks LOS
10D stacks LOS
10E stacks
11A stacks LOS
11C stacks
12B stacks
12D stacks LOS
12E stacks
01A stacks
01C stacks NOR
01D stacks LOS
02B stacks NOR
02C stacks LOS
02D stacks NOR
03C stacks
04B stacks
05C stacks
05D stacks
06A stacks NOR
