Camaro Research Group Discussion => General Discussion => Topic started by: KurtS on January 04, 2010, 11:24:01 PM
I'm updating the radius rod article and would like to illustrate the difference between the two designs of axle brackets (one for the rectangular rod, one for the round rod).
I'd like a few pictures of the brackets on 67 axles. I think some side and rear shots of the bracket would show the difference, but I'm not clear the exact differences myself. ;)
Rectangular rod axles should be under L78, Z28, L35/manual, and later L48/manual cars. The others should be round rod brackets.
http://www.camaros.org/radiusrod.shtml
Thanks for the help!
Kurt let me know if you got the pics I sent. I will get pics of the axle bracket tomorrow.
Kurt,
Do you still have the pictures of the three I sent you. I will see if I can dig up the pictures if you need them. It has been a few years.
I updated the radius rod article. Ron's pics were perfect.
I also started a research topic on radius rods: http://www.camaros.org/forum/index.php?topic=6247.0.
Russ,
I don't see those pics.
I still could use some pics of the round bar installed in a car (same angle as the rectangular bar would be great) and some of the axle brackets (without a rod installed).
Thanks!
