Camaro Research Group Discussion => Decoding/Numbers => Topic started by: GordonOne on September 10, 2009, 08:23:33 PM
During the assembly of the body, what did these UOIT tags look like? I may have one. Gordon
They are a big sheet of paper. About 11" x 15". They are not what I would consider a card. Post what you have and we'll help you ID it.
-Jon
Correction. I checked a UOIT I have in my possession and the dimensions are closer to 8.5" x 15".
-Jon
well i guess i dont have this card, what i did find in my feb 69 built van nuys car was, when replaceing the carpet i found a smashed GM coffee cup (paper of course) which had Quailty markings on it, and the other item was a manila card 3x5 from the Telegraph instan form company, which reads Job No........170-40227 Style 2437-711 comb A01-Co8 B last line Deck........nothing marked, this was found under the rear seat, the build sheet is still on the gas tank, and is very much stuck there, this car is a true SS block no TO208HB L525389 car built 02D VN273188, Gordon
That's a seat 'tag' or 'sheet'. It was basically a build sheet for the seats.
Does you car have tinted glass and vinyl top? 711 int?
yes it does have tinted glass, just for grins .....Lamisafety // M148 AS1 E2 DOT 459 43R-001296, all the other windows have PPG solex Herculite, and yes it has a black vinyl top.....standard 711 interior with Z-23 accent group.........car also has tilt, air, and rear window de-fogger, 14X7 rally wheels YJ.....rear spolier, standard SS hood.
Nice car Gordon.
Can you post a picture of that cup? I'd like to see what it looks like. :D
I know i have some where, we moved from Orange County to Northern Calif. and everything is boxed up, and since im a pack rat, i know i have, soooooooo one day i will post everything from the car, thanks for the reply, Gordon
