Camaro Research Group Discussion => Restoration => Topic started by: tinman on June 24, 2009, 01:57:28 PM
I need a saginaw 4 speed gear selector for a 1968 camaro or can i use another year model as a replacement. 8) ;D
If you need to be correct, you have to get a used one or buy a repro. The shifter is the same as for a Muncie except they have "Muncie" on the handle and the sag doesn't.
