Camaro Research Group Discussion => Originality => Topic started by: Pacecarjeff on March 10, 2009, 02:36:11 AM
Can someone post a picture of an original 1967 underhood lamp.
it has a single mounting hole, and functions in reverse.
I would like to see the backside where the wire comes out.
Thanks ???
Give me a few days and I will check mine.
how about this one - does this look like the right one?
been looking for a while. found this on a crashed 67 Nova a few weeks ago
I have one in my parts bin. I may put it on for the heck of it. Where does it plug in gentlemen? I do not possess a schematic.
or is this it?
I always thought that this was the one?
(http://img.villagephotos.com/p/2003-8/352217/ex1118.jpg)
It's taped, strapped, and clipped to the engine harness across the firewall and to the forward lamp harness on the driver's side inner fender, and the terminal goes under a screw connection on the horn relay.
Looks like I can use either one and just claim it is original?
Seems no one from this site will know the difference.
Funny.
I will choose lamp A as my original light.
Then I can just keep the other in it's original box
Jeff the one I thought was like the Nova one you have is not. The mounting bracket is different but the socket wire is the same, on all the lights I have. Perhaps your boxed light is OTC?
Picture posted on pacecarjeff's is correct. Believe lamp socket and shroud are all the same , but brackets are different. Bill
Jeff, let me correct my post. not the new in box lamp , but your original picture of the nova takeoff is the correct lamp. Sorry for ther confusion. Bill
Jeff,
I have a 69 lamp and could take a picture if it would help you. I would need your e-mail .
Victor
No the 68 and 69 lamp is different.
67 was a 1 year only that had only one mounting screw - it also faced the other way and worked backwards.
the back (the wire connection) is what I am concerned about - I am finding some discrepancies.
below is an original underhood lamp which went into production in 68
The 68 and 69 lamps were very common as they were used for many years - well into the mid 70's with no design change - it has 2 mounting screws.
Thanks - that is what I believe also. Still leaves me with a few questions -
the boxed NOS unit shows a part number that was for 57-59 Chevrolet full size.
but the design is what I would have expected for 67?
It may just be that a different vendor was used during that 1967 time period.
