Camaro Research Group Discussion => Restoration => Topic started by: 1968guppy on December 25, 2008, 05:26:47 PM
Hello,
I am new to this site. I am in need of a correct water pump for my 1968 camaro. It has a 327/210hp engine. The pump it use to have had two outlets.
Casting number# 3914678
build date# k 30 7
Hello,
Hi and Welcome -
You need to find a 3782608 casting number coolant pump with a casting date on it that works for your car. It will look like this...
Would this be the same pump for a 68 ss350?
my interchange book shows casting number 3890017, also fitting: 64-67 Chevy 2 v8, 65 chevelle 283 or 327/360hp, 66-67 Impala, 67 Camaro, 68 Camaro except 302
Colvin says 3782608 is the correct casting number for 68 Camaro 327/210 or 275 and 350/295.
3890017 is listed in the Oct. 1, 1967 P&A 34 as a service replacement part for 8 cyl. (exc. 396) Chevelle, Chevy and Camaro.
Hi, in the book , «chevrolet by the numbers» on page 222 , it says #3782608 for camaro 68 327 210
