Camaro Research Group Discussion => Mild Modifications => Topic started by: tom on November 17, 2008, 01:04:52 PM
Has anyone swapped a newer column into their first gen? I am swapping in a fuel injection from an 87 firebird, and one of the normal steps is to disable the VATS security system. I was thinking if I swap in the newer column, I could include the security with it. Might even get a tilt unit while I'm at it. If I do this and I put my original steering wheel on the new column I don't think most people would even notice it.
In my opinion, the 'nicest' customs are the ones which use later year same manufacturer components to achieve upgraded functionaiity in a very subtle fashion.. : but I doubt you're gonna find the right guys in CRG to answer your question, since this site is mostly (totallly?) concerned with 'originality' issues. I suggest going to TC to ask your question..
I have installed both 2nd gen and 4th gen steering columns in a 69 Camaro. The second gen was easy. The only thing I had to do was grind off the firewall plate, which is tacked on with a couple of spot welds. I then added the first gen firewall cover in place, which is bolt on. If you can find one from a later 2nd gen, you can have your bright switch on the column as well as tilt. The 4th gen is not as simple. The 4th gen is longer. Since I was upgrading to a rack and pinion, I did not have to worry about the length. Also, I had to cut off the column bracket that holds it in place and weld on the one form a first gen. Otherwise, it fit and looks good, with all of the advantages of the 4th gen column such as tilt, wiper motor, etc.
Do you know if the VATS (Vehicle Anti Theft System) software cares which gen column is used? The reason I was considering the swap is to include the VATS function on the computer form my TPI donor. Seems the easiest way would be to use the correct column.
I did not hook up the VATS wiring as I was of the correct way to get it right. I will post later if and when I learn how to or if you do, post it here.
