Camaro Research Group Discussion => Restoration => Topic started by: Sauron327 on October 31, 2008, 01:20:36 PM
Is this breather hose filter discontinued or am I mistaken? Thank you.
I bought several from Chevy a couple years ago.
What was the specific year and engine usage for that part? It's clearly a flame arrestor, and that function was served on most Corvettes by a fine mesh screen press-fitted on the end of the elbow inside the air cleaner.
I don't know. I found it with my NOS parts and referenced it in a catalogue which stated it's discontinuation. It is obviously not applicable to my 327 and thought it belonged with a different hose configuration. Or even if it pertained to Camaros.
Almost looks like it might go on a power brake booster.
Connection OD is 11/16. It's in Rick's cat. page 254.
I believe it's last application was on a truck. I will try to dig one out for a part # I know the parts places were removing the part #.
found em
The only Camaro application I can find for a separate flame arrestor is the '68-'69 RPO KD5 Heavy-Duty Closed Positive Crankcase Ventilation, but it used P/N 3924544 for all usages. All other crankcase vent systems used the fine mesh arrestor inside the air cleaner.
Part I have was manufactured by Fisher Corp., PAT. #3287094 ( Patent not Part) Would it's use be incorrect without RPO to substantiate?
KD5 required a plant-level rework of the air cleaner to drill the hole for the adapter elbow, install it, and plug the existing hole on the side; I doubt if many were built. I'd leave it stock.
Would this be the adapter of which you speak? There is no part# embossing.
The ones I posted were the ones they sell you to use with a crossram setup.
Would the one I posted be an OTC replacement? Charley, do yours have a GM part# on them? My arrestor has only the info above. If indeed it is for a crossram set up or unusual substitution as John indicates, mine would not be technically correct because it has no GM part # on it, no? If yours in fact do.
Mine have no part # on them.
Interesting. Have to wait for more knowledge to be posted. Thank you Charley.
Nope. The KD5 elbow was retained to the air cleaner base with a large nut and cotter pin; see the KD5 section in the Assembly Manual.
