Camaro Research Group Discussion => Restoration => Topic started by: onebad34 on June 22, 2008, 01:26:55 PM
I was at GM Nationals at Carlisle yesterday and noticed that the round Pressure relief valve under the Master cylinder was different on the 67 camaro's than the 68-69 camaro's. Is there a difference or is this a aftermarket issue. In all the parts catalogs, they list only one valve and state for the 67-69 camaro's. What is correct for the 67 camaro, big block, drum/disc car. Does anyone have the correct one for sale? thanks Pete
The same part number metering/hold-off valve (3905525) was used on J52 power disc/drum brakes in '67, '68, and '69. I suspect any visual differences are a result of production vs. Service vs. the new reproduction valves.
Had my car in concours and was told my Metering Valve was a 69. Was told on 67-8's the housing was smaller & the nut is different. Have to find my original now to compare!!!
Thanks for the reply, I was sure there was a difference. I could visually tell the differernce, Now, Does anyone have a housing that I can rebuild? thanks in advance Pete
No problem. When I find my original I'll post some pic's but it may be a while!
Hey Pete,
Looks like In-Line tube is repoping it. If you get it let me know what you think.
http://cgi.ebay.com/ebaymotors/67-68-Camaro-Nova-Firebird-Disc-Brake-Hold-Off-Valve_W0QQcmdZViewItemQQcategoryZ34199QQihZ009QQitemZ190231735562QQrdZ1QQsspagenameZWDVW
Hey thanks for the info. I went on line and you can see the difference between the 67/68 part no. PR114, and the one listed for the 69, part no. PR 105, I will be ordering one in the morning. Thanks again and I will keep you posted. Pete
