Camaro Research Group Discussion => Decoding/Numbers => Topic started by: crobjones2 on April 01, 2008, 05:12:26 AM
Has any one seen this before?
It appears to be a "3M" on the fender extension
That's the assembly sequence number, so that part meets up with the other parts for the same car with the same sequence number.
Would the other fenders have the same markings?
Some COPOs have 427 written there so the fenders would not be pierced for an emblem.
Fenders, gas tank all kinds of parts...
Note the "80" at the top right on the Gas tank...
(http://www.crossroadspaper.com/060.jpg)
Also on the Heater Box
(http://www.crossroadspaper.com/067.jpg)
i wish i was computer savvy enough to print pics, but my 67 rs/ss has "R" inside the lower fender extensions. also the sequence number, along with RS inside the lower valance. email me and i can send them if anyone is interested.
buddy
I also found a " 21 NOR" on the door - paper tag glued on
That's a verification sticker for warranty glass adjustment claims.
John
Are intact tags very common?
John
Probably more common if the car hasnt been messed with much, My car still has it's tags on the doors. All cars had them.
Here is one from a COPO that I owned as Bill mentions. It was written up side down.
My 69Z tank was marked with "63" in the same color paint pin, located on the same rib as firstgenaddict's, but toward the center of the rib.
My heater box also had a "63" red paint pin marking in the same location as that shown.
What did these markings indicate?
Was this from your 69 SS 350 in your sig? If so could you give me the build date, plant and trim code. Thanks
That post was from 12 years ago, and he hasn’t posted anything in over 3 years. Good luck.
Had to ask regardless
