Orphans - documentation or VIN-stamped drivetrains - in search of the original cars => 1969 - Orphans => Topic started by: melav8r on August 28, 2007, 06:22:00 AM
Your block on eBay:
http://cgi.ebay.com/ebaymotors/1969-Camaro-Z28-DZ-302-X33-Engine-V0123DZ-Block-3956618_W0QQitemZ300145448105QQihZ020QQcategoryZ140682QQssPageNameZWDVWQQrdZ1QQcmdZViewItem (http://cgi.ebay.com/ebaymotors/1969-Camaro-Z28-DZ-302-X33-Engine-V0123DZ-Block-3956618_W0QQitemZ300145448105QQihZ020QQcategoryZ140682QQssPageNameZWDVWQQrdZ1QQcmdZViewItem)
My bet is this block is a restamp. This seller (carss_partss) has had many restamped blocks on Ebay that Kurt and others here have identified. He also has other Ebay IDs (i.e. fixxbrakes) = scammer. >:(
No sale on 9-2-07.
Reserve not met = ?
If it was a restamp, he did his research as the block cast date, and engine assembly date would have been dead on with when VIN # 19N587857 would have been produced.
Richard -
Unfortunately, based on his past behavior, I'm very suspicious of anything this guy sells. :( Read this CRG thread and the CRG thread mentioned within it: http://www.camaros.org/forum/index.php?topic=2530.0
Read the post by CRG member 69LM1 and use caution if you're thinking about buying! Good luck.
