Camaro Research Group Discussion => Maintenance => Topic started by: ss68396 on June 18, 2007, 05:31:40 PM
Title: Big Block Motor Mounts
Post by: ss68396 on June 18, 2007, 05:31:40 PM
Hey guys,
Im having a hard time finding a set of Polyurathane Motor Mounts for my 68' BB. Do you guys have any ideas or suggestions where a guy can pick some up. I have already ordered the Hyper-Flex kit from energy to redo all the factory bushings so far.
Any help would be very appreciated.
Also would you guys say a solid mount is better vs. the rubber mounts for my application. 454 approx. 300hp with 4 speed
Jay
Title: Re: Big Block Motor Mounts
Post by: JohnZ on June 20, 2007, 06:40:15 PM
BB's used the same engine-side mounts as the 350 and 302. Solid mounts will shake the fillings out of your teeth.
Post by: ss68396 on June 20, 2007, 09:32:55 PM
Thanks alot John.
Post by: sd1968z28 on June 26, 2007, 03:29:10 PM
go  to your local chevrolet dealer and get the facory mounts, i beleive they are still avaliable and will work fine and fit perfect.
