Camaro Research Group Discussion => Maintenance => Topic started by: 69aus on June 01, 2007, 12:30:41 AM
Can any one post a circiut diagram or instructions to bench test a 69 Wiper motor ? I have the "in car" test diagram ang "no go". Now would like to test isolated from the dash switch and car.
I want to prove the thing works by itself :-\ and prove the problem is then the wiring in the car. Have already replaced the dash switch
Driving me mad trying to get the wipers going >:(
Thanks in advance
im not sure if this helps any but i had to go through 3 OER wiper switchs before i got one that worked properly. this post had some good info on how wire one maybe it could help
http://www.camaros.org/forum/index.php?topic=2152.0
Thanks for the reply. I guess what I want is take the wiper motor off the firewall and test it. And by process of elimination find the >:( problem.
I understand the stand alone pin is 12 V + and the other 2 work ( light blue and dark blue ) work by earthing. I dont wont risk the motor without prior knowledge though :-\
New 69 wiper motors are not exactly thick on the ground in Australia ::)
HELP, AM DESPARATE :P
Do a search for wipers don't work. Their is a post their that may help.
Good Luck:
Sam
Thanks mrdetails, regret nothing there on benching testing. the main info I need is which pins to apply 12 volts to check operation.
Here you go. Remeber, the wiper motor is always hot, and it grounds through the switch to the dash.
Thanks Mark
Awsome ;D
Peter
