Camaro Research Group Discussion => Restoration => Topic started by: 67rscnvt on May 31, 2007, 01:16:10 PM
Did the trunk get spatter painted before or after the convertible weight balast were installed?
You really ought to post this question under originality. It won't get much notice here...
I believe Jerry answered this recently in another thread.
The trunk was painted after the shakers were installed. I have seen unrestored cars with splatter paint on the shakers.
The shakers were installed after the trunk was painted. They were hung in the trunk, painted with the trunk, and then installed.
The bolts will not have splatter paint on them. :)
Kurt is correct - if the shakers had been final-installed in Paint, they would have blocked access to install the rear marker lights, taillight housings, and outer bumper bolts; they were final-installed in position in the Trim Shop after those items were assembled.
That solves the mystery as to why the shakers had paint. Thanks for clearing that up.
