Camaro Research Group Discussion => Restoration => Topic started by: vabeach56wagon on May 16, 2022, 03:05:10 AM
Does anyone have either a source for the Saginaw lock out rod (shifter to bellcrank) or its dimensions so I can make one to spec.
Small-blocks use lower lock rod 3955773 on the Saginaw, not the same as Muncie, seemingly much shorter rod due to the difference in placement of reverse in the cases.
